Question about New World Ovens
I have a new world tg090 double gas oven. It stopped working last night. The clock is off and there is no ignition spark yet the fan works. Anyone know what is wrong
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Posted on Jan 07, 2009
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
barkencoa
  • 3463 Answers
SOURCE: We have Smeg DUCO8CSS double electric oven. Bottom
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 18, 2010
Why has my oven and grill stopped working?
manufactor have recalls check the website to see if it includes your item. electronic controls due go bad
May 26, 2014 | New World G70m Gas Double Oven
None of the buttons are working and clock is not displaying. Just happened last night after use and the only thing working was fan.
Um, is the fan working now? No? >> check power to oven
Circuit tripped? >> check for electrical fault / mice in wires
Oct 16, 2013 | Maytag 30" Built-In Double Electric Wall...
Grill ignition spark persists when oven on ! how to remidy the problem ?
New electrode or a short on the spark box or electrode out of postion
Oct 31, 2011 | New World G90m Gas Double Oven
Ignition not working although there is power to the cooker (oven fan working)
we turned it off at the plug left it for a 5 minutes it then worked again
Jul 27, 2011 | New World G70m Gas Double Oven
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Sep 15, 2009 | New World G70m Gas Double Oven
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
Hi
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Clock
why did you have a new clock fitted and did you do it yourself? check at the clock to see if power present. if not, check the wiring loom to see if any breaks especially at any plugs and sockets. if you do not use the automatic function, you may want to bypass the clock
Mar 29, 2007 | New World G90m Gas Double Oven
Ovens Logo
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
