Question about Epson Perfection 4490 Film / Flatbed Scanner
Epson 4490 scans with colour streaks/ digital interference
I am scanning 120mm film negatives in a day old Epson 4490, positive and negative, with and without the neg holders and more often than not I am getting streaks of colours across the scan, it looks like a digital colour noise.
This scanner is brand new and is frustrating me! Thanks in advice for help.
  • 95 Answers
Did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Posted on Sep 14, 2009
My Epson Perfection 4490 Scanner insists on scanning my 35 mm slides as regular color photos. How can I switch the dscanner to scan my slides as slides?
Of course that is what it will do. The same as ti will do as a negative. Neither can be printed out other than as a picture.
Sep 01, 2010 | Epson Perfection 4490 Office Flatbed...
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
Negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Epson Perfection 4180 Photo Flatbed...
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Streaks of color when scanning film
you need to clean of reflection glasses of lens so if you are handy on it then take off fron scanning glass and take out glasses and clean the out with clean cloths.
and put them back.
note: if you are not aware of it please do not mess up with them because it will be more annoying.
good luck
please rate all answers.
Apr 06, 2009 | Epson Perfection 4490 Film / Flatbed...
Scanning OLD Negatives - old browning? Scanner is cutting half
you better not used the automatic detection of the pictures, it never works fine
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Epson Perfection 4490 Film / Flatbed Scanner Logo
420 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
