Question about Whirlpool Refrigerators
Freezer drain is full of water and freezes up and water ends up getting on floor. How can it be unplugged?
  • Whirlpool Master
  • 1,606 Answers
Remove the food from the freezer and ice maker ( if equipped ) . Remove the screws from the back panel , and remove the panel . Use a hair dryer , starting in the middle , below the coils , and defrost until you see the drain hole . Use hot water to help thaw the drain hole . Once water flows down , use a small hose inserted into the hole , and blow thru , to remove any debris accumulated in the drain line . Get a piece of ALUMINUM solid wire ( 14 - 16 guage ) about 9" long , completely stripped of insulation , and insert it into the hole as far as possible ( without force ) . Wrap the other end , about 1-2 turns around the black rod ( defrost heater ) just above the hole . When the refrig goes into defrost , the heat will transfer to the wire , keeping the drain hole from freezing up again .
Posted on Sep 13, 2009
Water is leaking on then freezing on the floor of my upright frigidaire freezer. At first I just thought it was a fluke and cleaned it out, but he next day their was frozen water again. I also am finding...
Your freezer goes to a defrosting cycle and actualy melts away some ice formation inside the freezer, normaly this melted ice (water) drains trough a tube in the back of the frig... the drain is probably clogged and the water spils out... to unclogg it you need to find the uper end of the drain (where the water drips in) usualy way in the back of the frigidaire, than try pushing a long wire in downwards to unclogg the drain, also check underneath or in the back of the frig. ther should be a back to hold the water for the time it evaporates, see if it is not full of water or dirt (dust) i even foud some pet toys in there once ha! ha!
Hope this helped!
Mar 02, 2011 | Microwave Ovens
Kenmore Elite 795.75542401 Water freezes on the bottom & then spills out to the floor. We can't find a drain hole anywhere!!
There is the drain in the freezer under the evaporator. You have to remove the rear panel in the freezer and the freezer floor to access it. Defrost it using a hair dryer and put hot water through the drain to make sure it's clean. Make sure the bottom end of the drain hose (behind the rear cover) is clean as well. Vacuum everything in the compressor compartment and keep it clean.
Please check the useful links bellow related to your query...
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
http://www.ehow.com/about_6736707_water-freeze-floor-bottom-freezer_.html
http://www.ehow.com/how_2208484_that-leaks-water-down-refrigerator.html
Let us know if you want something else please accept the solution.
Sep 20, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dripping from freezer into refrigerator area and frozen water in freezer
The defrost cycle is melting ice that will not go down the drain tube in the rear of the freezer. This can be a clogged tube due to debris, organic growths or ice blocking flow. What doesn't end up dripping into the fridge ends up freezing in the freezer compartment. Make sure the fridge is level or tilted back slightly.
Unplug the fridge from power. Remove the contents of the freezer and remove the ice maker, back wall plate and floor plate in the freezer section. Remove ice build up on the floor and tray in the freezer by thawing and soaking up water. Flush hot water (use a turkey baster to get at it) at the opening of the drain hose that is connected to the tray to thaw any ice.. once flowing to the evapraor tray under the fridge, mix up 1/2 oz of bleach and 4 oz of water and pour down the tube to kill any bacteria.
Reassemble and restock the freezer. Monitor the temperature of the fresh food (34 deg) and freezer (0 deg) compartments. If you notice the temperatures start to climb, there may be a problem with the defrost timer, terminator, etc. and may require a pro's help.
Mar 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Sep 22, 2009 | Maytag Refrigerators
Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jul 02, 2009 | Refrigerators
About every 2 months the defrost drain gets plugged
Jul 01, 2009 | Whirlpool ET8WTKXK Top Freezer...
Kenmore 106.71299100,water freezes on floor of freezer,drain line freezes,I have opened drain with hot water etc.then problem returns in about one month. the refrigerater is 6 years old and this problem is...
You have a partially plugged drain, causing water to flow too slowly. Try reaming out the drain with a long stiff wire until water flows thru it like a faucet. You may have to unplug the unit for a day to get every part warm enough. Hope this helps!
Jan 28, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
