Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 door wont open
Hotpoint wf860 washing machine door wont open because water not draining out
  • Hotpoint Master
  • 3,463 Answers
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Posted on Sep 13, 2009
  • 3 Answers
Pump is possibly blocked. Unplug then remove lower rear panel (2 screws) and disconnect wire loom and hoses. Slide pump unit to left and lift out. Open pump (3 screws) to clear blockage and also ensure that hoses are clear while pump is removed. Re-connect ensuring that hoses are straight and not kinked!! select spin programme ad this should fix the problem. If not then you pipes may be blocked under the sink.
Posted on Sep 17, 2009
SOURCE:
How do i open my door on the washing machine it has finished the programme but wont open and washing is still in the machine
If all the water has drained away. POWER OFF. Lid has to be removed. slide arm down inside of front panel to door lock and rease it. A new door lock would be required. An engineer can do this
Oct 03, 2014 | Hotpoint Ultima WF860 Front Load Washer
Key symbol is on cannot open door
If there is water left in machine door stays locked but if you remove the plug after about 3 mins the door may open be careful if there is water in it when you open the door
Mar 25, 2014 | Hotpoint Ultima WF860 Front Load Washer
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
My hotpoint ultima has stopped halfway through a wash and has the word door flashing.
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Cannot open door
f5 means a blockage. you will need to drain it by putting the drain hose lower than the machine to syphon it out into a basin. then you can check the filter for the cause.
Jan 27, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
377 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
