Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Can't regulate water temperature
Bosch Aqua Star Tankless Gas Water Heater D 2400 E (propane) We have had this product for well over a year now. With the temp turned down as low as it will go, we either get scalding hot water or freezing cold water. The water will turn cold if there is some other source of water turned on at the time in the house. It does not matter whether it is cold or hot water turned on in another place in the house.
If we try to adjust the temperature, it will turn ice cold also.
This is not a new problem. It has been this way since the installation.
Is it because there needs to be some sort of flow control valve on either our well or water supply going into the tank less heater?
Please advise us on any ‘fixes’ that we can make to this water heater to make it more like our old ‘conventional’ water heater. Also if you sell the part that may fix this problem, please advise.
  • Bosch Master
  • 2,458 Answers
Slower the flow hotter the water is how it works . Sounds like the water section is blocked and could well need cleaning out . Draw back with this system is you need a good inlet flow and flow will drop when you open other taps . they are good for a small house a family house not that good . Not much you can do put in a bigger water inlet to heater ?
Posted on Mar 11, 2017
  • 11 Answers
SOURCE: does grundfos rcp96 pump work with bosch 2400 eo tankless heater?
What is your reason to have a recirc line on your water heater does the heater sit to far away from a certain fixture? If you put a pump on your tankless waterheater then your heater will continually fire till the call for hot water is stopped. Yes you normally do need a seperate line installed for a recirc line usually from the water heater to the farthest fixture away. If your problem is taking to long to get hot water then I suggest installing a second heater closer to problem area.
Posted on May 25, 2009
  • 11 Answers
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q. FA - Gas leakage error, gas valve circuit not closing properly
A.
  1. Disconnect power supply cord and check wire connections on gas valve and the two connectors on the control board.
  2. Flow water out of a hot water tap above the minimum activation point of .8GPM. Measure voltage at the gas valve wire connector. The connector should measure 24VDC between the left pair of wires and 24VDC between the right pair of wires when the unit is operating. If voltage is not correct, contact Bosch Water Heating for further instruction.
  3. Gas valve may be defective, contact Bosch Water Heating for further instruction.
Q. EA - No flame ionization detected with water flow
A.
  1. Verify that all manual gas shut off valves are open.
  2. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air from gas line (especially on new installations). Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  5. Verify gas pressure meets specifications outlined in chapter 3.8. See Bulletin TWH-G2-03.
  6. Verify venting meets specifications outlined in chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  7. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If not, Call Bosch Water Heating with observations. Readings from above gas pressure test will be required.
Q. C1 - Fan rotation too low on startup
A.
  1. Disconnect power supply cord. Check wire connections on back side of fan and the two large wire connectors on the control unit. Removal of lower access panel on control unit is necessary to access connectors.
  2. Verify that supply voltage is 120VAC and is properly grounded.
  3. Verify that venting meets specifications outlined in chapter 3.6 of the installation manual. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure. Verify backdraft flapper inside flue gas collector is not stuck shut.
  4. Check gas pressure. See Bulletin TWH-G2-03. Low gas pressure may cause the fan to change its speed to meet desired temperature.
  5. Possible defective control unit. Call Bosch Water Heating for further instructions.
Posted on Mar 15, 2009
kevin000
  • 1847 Answers
SOURCE: Bosch tankless GWH 1600 H NG won't always ignite
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Posted on Mar 29, 2009
SOURCE: why am i getting a A3 error code on my bosch aqua
Question is though, why would this fail after only six months?
Posted on Dec 08, 2009
SOURCE: bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Posted on Feb 23, 2011
Bosch Aqua-star tankless water heater had water on gas valve, dried gas valve, I have a spark but will not light
Water in the gas valve is DANGEROUS! The major question is did the water come from a leaking heat exchanger or the product of combustion? If it is from the heat exchanger it may be covered under the warranty (if the installation is proper). If it is from condensate in the flue pipe, it is from an improper installation. If you go to bosch-climate.us you can find a service provider in your area. I service a very large part of NY, some of NJ (Northern) and all of CT.
Sep 05, 2013 | Bosch & Tankless LP Hot Water Heater
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Aqua star runs on and was running water to out side I guess it would be the overflow ( tankless). Had to turn the water off
Problem is not clear
Before calling service technician, open following link for Bosch troubleshooting resources including contact information for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 09, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Bosch on demand tankless water heater gwh 2400 E LP error code "
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Had the unit for seven years, it started to leak water around the water valve. Bosch aqua Star 125x ng
You have to fix this leak around the water valve before
it causes damage to your equipment.
1. Close the water supply valve going to your tankless
water heater.
2. Unplug or close the natural gas valve.
3. Now, you can work fixing the leak.
4. Once completed, you can proceed to open the
natural gas valve as well as the water supply valve.
5. Then, have it tested to get it done.
5.
Nov 27, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Does grundfos rcp96 pump work with bosch 2400 eo tankless heater?
Apr 16, 2009 | Grundfos RCP-96 Recirculation Pump for...
Is there alot of problems with bosch aquastar 2400
Bosch has had problems with these heaters for sure. They are the best known thing out there in the market.They are mostly responsible for the bad rap being given to all tankless heaters, but a big part of the problem is installation. They are being sold to homeowners at box stores as DIY kits. These are not units to be homeowner installed, venting and fuel requirements are different from regular heaters and they will not function correctly if improperly installed. I have installed several of the Rannai units over the past few years without any issue whatsoever.
Mar 10, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Turn on water the electronic ignition not coming on
The tankless water heaters require larger gas supply lines because of the on-demand consumption. While I don't know your units rating, most Propane Tankless Waterheaters require 2" supply lines. Moreover, pressure is directly related to temperature which sounds like your problem entirely; consider the run of the gas pipe from the tank and the ambient temperature. Now you see why plumbing is a hard profession to fake... =)
Nov 19, 2008 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
222 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
