Question about Logitech Z-2300 Computer Speakers
I've lost sound in one speaker
I keep losing sound in one of my speakers, however when i fiddle the 3.5mm wire for the input it gets better but it takes alot of fiddling what could be wrong???
  • kuz_2010 Sep 13, 2009
    Thank you the connection is perfect no damage at so I'm just going switch the wire over and see it works...
    President:
  • 1,179 Answers
Check the wire for frays, missing insulation, broken area, loose fitting, etc. It sounds like there is something that is not making a proper connection. "Fiddling" makes it better leads me to believe that a bent area, frayed wire or such has it not making a full connection. You may need to replace the wire to that speaker in order to correct the problem. If the unit is still in warranty I'd suggest contacting a Logitech repair center for this. If it is not then you can do this yourself if you are comfortable working with a soldering iron. Just make sure you use properly rated speaker wire and connect the wires properly. Hope this helps.
Posted on Sep 13, 2009
Why did my receiver lose volume on the right channel
I will assume this right channel problem is present no-matter the chosen input....radio, CD, etc. "Changed speaker wires"...did you swap ONLY the wires from left channel to right or did you also swap speakers? Defective speaker woofers (wiring and/or crossover failures) leave only the tweeter to reproduce music in that speaker, which we perceive as both a huge volume and tonal reproduction difference compared to the "other" speaker. Keep up your "process of elimination" troubleshooting techniques as this will lead you to the problem.
Mar 27, 2015 | Audio Players & Recorders
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
I've connected an IPod to the main speaker microphone input; I get no sound at all.
The connection you made is wrong. You have to connect the phones form the IPod to any available line in of your amplifier - audio system using a cable like this
This cable is common known as 3.5mm male jack to 2 male RCA.
In case you'd like a link to buy on line this cable or if a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 11, 2011 | Boston Acoustics BA745 Computer Speakers
I cannot get a sound from my pc. where do i connect the speakers
If the speakers has the common round 3,5mm jack you have to plug it in the green hole at the back of the power. If the speakers has a USB connector you have to put it in any available USB connector at the front or back panel of your computer's tower.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 02, 2011 | Compaq Presario SR5710Y PC Desktop
Changing the omes of a 4 10'' bass cabinet
i guess ur talking about four nos of  4ohms 10" speakers. two speakers of four ohms connected in series gives 8 ohms, but if u use parallel connection u will get half of individual ohms i.e 2 ohms. so connect two speakers in series and another two speakers in series. parallel the two serial speakers and voila... u get a 4ohms speaker with double the wattage.
parallel connection - connect +ve to +ve and -ve to -ve.
series connection - connect -ve of one speaker to +ve of another speaker so that u have +ve input to one speaker and ground(-ve) on the second speaker.
So, two separate series speaker then parallel the two series speakers.
Mar 12, 2010 | Audio Players & Recorders
I lost the input output wire to my surround sound for my computer
Contact the manufacturer of these speakers. Visit their website or find their phone number and request a replacement wire. I understand your frustration because the same thing happened to me. I have a Sony speaker system, and i lost the input output wire so all i did was called the company up and they sent me a replacement wire in the mail. It should not cost much at all. Any further questions, let me know so that i can resolve this issue for you.
Jan 20, 2010 | Spherex Xbox 5.1 Surround Sound System...
JCM2000 DSL100 No Sound
Not likely to be a fuse. The bane of electrical amps are the connectors.
Often the speaker and more commonly the input 1/4 inch connectors go bad. Sometimes caused by side loads when cables are yanked or tripped over.
Be careful of running amps IF the speakers are not connected OR have bad connectors or cables. You can arc over the tubes or pop transistors.
Get a cheap Volt-ohmeter from HarborFreight or Radio Shack and test your cables and connectors.
For a tube amp, your should find relatively low resistance at the speaker connector (certainly under 20 ohms). Do this with power off.
Sep 09, 2009 | Marshall Music
I need the red/white speaker cords with a pin on other end to hook up bose speakers on my computer
Does a regular 3,5mm headphone plug plugs in? if yes, you can use the standard cable found in every electronics store. If it is smaller, an adapter could be needed. that adapter is as easy to find. Explain the case to Electronic store salesman, or better, show them to him/her.
Aug 31, 2009 | Boston Acoustics BA735 Computer Speakers
Left Speaker Stopped Working
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Apr 24, 2008 | Altec Lansing VS4121 Speaker
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Logitech Z-2300 Computer Speakers Logo
400 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
