Question about Motu 896HD
Lost asio buffers
Hi
I have a new motu 828 mk2 with the latest driver used with samplitude 10. xp pro
I get a lot of lost asio buffers.
my old pc was a pentium4 ,2gb ram and sata hd.
i upgrade it to quad 2 core,4gb ram and a new sata hd, i still have the same problem.
can anybody help here????
motu does not answer calls and their replying emails are useless.
thx a lot.
2 Suggested Answers
SOURCE: MOTU 828 MK2 Problem when connected to computer
Hey guys I've had this happen as well. What worked for me was the reset function. Disconnect the MOTU from the computer. Go to SETUP, turn the knob to FACTORY DEFAULTS, press SELECT, then VALUE. Reconnect MOTU to the computer. I've heard that this doesn't help everyone, but it's helped me.
Posted on Jul 05, 2009
When I record with my m-audio mobile pre USB, there is no latency issues with recording but there is a delay in the headphones if I turn them up to hear myself while recording. How do I fix this? I'm using...
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
http://www.image-line.com/support/FLHelp/html/recording_audio_USBmic.htm
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
Feb 15, 2015 | M-Audio Computers & Internet
Vaio vgn n31 does not detect motu 896hd
MOTU 896 IS A VERY USER FRIEND SOUND CARD. IT WORK PROPERLY FIREWIRE CARD STANDARD PIN. YOU CAN USE ANY FIREWIRE CARD AND USE NUENDO4 FOR BETTER RESULT
Apr 26, 2010 | Motu 896HD Sound Card
Motu traveler some times make digital kind of noise and all lights on the display randomly blinking - how it possible to fix it ? I have a windows XP pro SP3 32 bit and all latest drivers for MOTU...
 may be this is problem by powerunit. you should be betteer result by xp sp2. for leopard 10.5 you must registerd yuor product by motu then you download update mac driver, thanks
Apr 04, 2010 | Motu 2408 mk3 Digital Audio Interface...
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Drivers motu896hd
Vous pouvez l'obtenir du lien ci-dessous
http://www.download.com/MOTU-828-896-drivers-for-Expansion/3000-2025_4-37758.html
Faites-moi savoir si vous avez besoin de plus d'aide
Mar 01, 2009 | Motu 896HD
Feb 11, 2009 | Motu 896HD
Motu MK2-2408 PCI-324 WIN-2000 and XP/ no conection to interface
check in control panal, check the following folder:
default programs, network and sharing center, problem report,
realtek hd audio m, sound,serity center, system, windows firewall,
last check windows updates
after that if you conitunueing to have these issues i will help you fether on this problem
rod is the candymangandy
Jan 26, 2009 | Gigabyte GA-6VTXE-A Motherboard
ASIO Driver give chopper sound in fl studio
You might wanna try to increase the ASIO buffer size (perhaps a lot) ...
And if that doesn't help, you might wanna try the www.asio4all.com driver
Jan 03, 2009 | ASUS Intel 440LX Chipset P2L97-DS...
Motu micro lite
Log into Motu.com with  UN - fixyajames PW - fixya
Hope the download fixes the problem.
James Mac
Sep 09, 2008 | Motu Mark of the Unicorn Micro Lite USB...
MAgix Samplitude
If you download the Samplitude Demo you can use the help file located in the installation folder.A lot of it relates to Samplitude SE if you miss out all the Pro bits.
The manual with Samplitude SE seems to deal more with Sequoia.
Link to download demo of Samplitude: http://www.samplitude.com/dltrials/Samplitude_10_pro_demo_E.exe
Mar 12, 2008 | Adobe Photoshop 7.0 for PC
Motu 896HD Logo
78 people viewed this question
Top Motu Computers & Internet Experts
Jay Plesset
Terry Hair
Are you a Motu Computer and Internet Expert? Answer questions, earn points and help others
