Question about Garden
Mower want start or stop after a few seconds oil ok slightly too high petrol in sparkplug rubbed. button to prime not filling when you look inside it is empty. What can I do? stiga collector 45 combi
  • David Zawatski May 11, 2010
    Filter may be plugged if any, Gas Line Leak, May need new Primer Bulb ! Did not understand your comment on the Spark Plug ?
  • 389 Answers
Clean out the carburetor float bowl and the main jet in the center of the carburetor
Posted on Sep 15, 2009
Our victa lawn mower is a 2 stroke and someone has put unleaded petrol in it, now it doesn't run, how can I fix it?
Try flushing the diesel out of the system with 2stroke fuel, replace the spark plug and try restarting!
Dec 30, 2014 | Garden
Hayter spirit 41
Drain tank, flush with gas. Remove float bowl from bottom of carb and clean. Fill tank with fresh gas and Stabile. Prime 3-5 times. Pull rope 10 times to start.
May 27, 2013 | Garden
Masport 4 stroke mower...started it up and it worked for a couple minutes with a strange rattling growling noise.. Oil ok and petrol filled but the mower just shut it's self down and im not sure w
It will run for a few minutes and then shut down?
Lets ignore the growl for now. Loosen Gas cap and see if it will keep running. The rattle might be in the pull cord mechanism..possibly not related to stalling issue
Dec 03, 2012 | Garden
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
Mower won't start. Toro mower..engine won't turn over. Cleaned sparkplug...checked air filter..weather cool. Followed instructions for cold engine...prime witrh three pushes of the bulb..wnon't even hint...
Something everyone over looks is oil. Did you check the oil? You seemed to mention everything else but. If you have a low oil switch with low oil it will not start
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Mower starts and stops with in a few seconds
Ok your not getting fuel into the carburetor it sounds. This could be either your carb.needs cleaned or your low idle screw on the carb. needs adjusted. The idle screw is located directly underneath the air filter. Remove filter and turn clockwise all the way and then counter-clockwise 2 1/4 turns, then test. Adjust until it sounds about right.
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
Garden Logo
203 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
