Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Replacement for Honeywell ST100 heating & hw programmer.Thanks
5 Suggested Answers
SOURCE: No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Posted on Sep 17, 2008
cactus bob
  • 267 Answers
SOURCE: Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Posted on Jan 15, 2009
t1m130
  • 86 Answers
SOURCE: Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Posted on Jun 30, 2009
  • 2522 Answers
SOURCE: Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
Posted on Feb 18, 2010
Hw and ch not coming on auto , will come on if reset but following day will not come on again until reset , there is no red light on , on the time guard does this have any thing to do with it?
Hw & ch in my vocabulary means Hot Water & Chiller. I have never seen this on a thermostat. I'm also assuming by time guard, your saying time delay. The time delay only goes into effect if there is a power interruption.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Nov 04, 2012 | Honeywell Programmable Thermostat Heater
Programmable Thermostat Heater: no power to honeywell central heating control...
Multiple possibilities:
Damage to cable (doing any DIY?)
Failure of thermo
Board gone in heat unit
Possibly simple as loose or disengaged connection, check at thermo & heat unit, if nothing obvious, call serviceperson.
May 18, 2010 | Honeywell Programmable Thermostat Heater
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
328 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
