Question about GE DCL333EA Dryer
My electric clothes dryer has started to occasionally make noise. could it be a bearing or a belt this is slipping. It's a GE machine about 12 years old.
    President:
  • GE Master
  • 1,922 Answers
Could be the belt,drum glides,rear drum bearing or the idler pulley is weakening and letting the glazed belt slip on the drum
Posted on Sep 20, 2009
Squeaking and want to know how I can fix it please
most likely it is either the belt or one or more of the wheels the drum rides on. a belt stretches as it ages and can start to make noise as it slips on the drum or motor pulley. wheels/bearing also can make noise as they wear. another possibility is the tensioner that takes up the slack on the belt. if the dryer is 5+ years old or older, i personally would replace all the wheels(4) and the belt and lube the tensioner and have it all set for many more years. wheels are about $40 on eBay and the belt is about $10. other good sites for getting the correct oem parts are repairclinic.com(not the cheapest but always good parts and good return policy) or appliancepartspros.com(good prices/oem parts)
Apr 02, 2015 | General Electric DWXR483EGWW 6.0 cu. ft....
I have DBSR4EB3WW model number. Last night I was drying clothes, tryed to turn dryer back on , turned the button to right to start clothes and all it would do is make a humming noise. ...
Hello Deborah, it could be a number of things, First the belt, usually if you hear a humming and the drum isn't turning, Its a broken or slipped belt, the hum you hear is the motor turning, But with no belt the drum can't turn other things that can go wrong and cause this are the safety switch located by the dryer door has failed, or a thermostat located in the rear of the machine is bad or stuck if you feel you can check these things , thats cool, just let me know you want to give it a try ,
Jun 16, 2011 | GE DBSR453EBWW Electric Dryer
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
Dryer makes noise that sounds like tumbling glass and smells hot
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 19, 2010 | GE DBSR453EBWW Electric Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
Dryer louder than used to be, does it need service?
The belt may be worn and squealing because it is slipping.  When it warms up it stops slipping.  It will have to be replaced soon. A worn bearing on a support wheel could also cause intermittent noise.
May 29, 2009 | Amana ALE643RB Electric Dryer
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
Dryers Logo
213 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
