Question about Samsung Televison & Video
I have samsung UA32EH 6030 tv,there is 30 % screen black out and some lining, is there any solution to repair this or have to replace full panel?
    Habit-Forming:
    New Friend:
  • 123 Answers
Check connectors from main board to screen. Clean with electronics grade alcohol and reseat. Panels are normally fine. It's the driver board or connections.
Posted on Sep 02, 2019
SOURCE:
  • 179 Answers
SOURCE: Samsung 42" Plasma-SPN4235 screen problem
the panel itself has failed
Posted on Dec 01, 2007
mistersony
  • 320 Answers
SOURCE: lcd screen
You can get the panel replaced. The problem is that the cost of replacing the screen usually exceeds the cost of repairing the unit.
Posted on Oct 19, 2008
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
  • 124 Answers
SOURCE: Samsung plasma all black screen
Black Screen come from three areas. 1- Power Supply Board 2- Inverter Board 3- Processing Board on the LCD. Since the Power Supply Board was replace, it easy to troubleshoot where the problem. lies If you cannot get the backlight, then its the inverter board. If you can use a flash light on the TV screen and can barely see the images, then the problem is indeed the inverter board. If you cannot see any images when using a flash light, then the problem comes from the LCD processing board. Let me know if you have any success. Mike
Posted on Feb 21, 2009
  • 304 Answers
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
SAMSUNG - UE40F6670 LED TV - I have thin black horizontal lines appearing in upper half of screen. They get lighter as the TV warms up but don't go away.
IMPORTANT: Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). Check ribbon connectors coming from screen and the T-con board first but likely the Panel.
Dec 28, 2016 | Samsung Televison & Video
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
Jul 15, 2013 | Samsung UN Televison & Video
I have a Samsung LN46B530 LCD TV. There are 2 parellel lines on my screen, tv is 2 years old, first started with 1 thin line in the center of the screen, now that one has gotten thicker, and another one...
These lines came on to the tv LCD screen panel by itself?Yes,than the board that call the T-CON board it is dying to causes this problems,if these black lines problems causes by u or an object by hitting it to the tv LCD screen panel itself,it can't be repair,the tv LCD screen panel itself it is dead and leaking radiations.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
Jun 22, 2011 | Samsung LN46B530 LCD TV
I have 42 inch lcd tv, which is not displaying any picture. i had purchased it on 27 sept 2009. it is couple of days above the warranty period. but the samsung people are asking to get the tv panel...
Where do u live,which country is this? $52,000 i can buy a brand new car for this price.If the tv LCD screen panel is damage or broken.The tv is useless,only can,must be replace it with another LCD screen panel,the tv screen panel are 90% important to the tv.30% of the cost of the tv to replaced the LCD screen panel is fair.U don't take the offer,the tv LCD screen panel is damage or broken,will not able to buy and replace by any other tv shops technichains.The LCD screen panels are limited production by the tv corporation.
Oct 17, 2010 | Samsung Televison & Video
Red thin line on left side of screen / black colours have a burnt red tinge over them. TV is 30 months old
If that line is permanently on the screen  - even when you are using the AV signal then the LCD panel is busted, no way to repair it. Try getting it replaced under warranty, it shouldn't have failed so soon
Oct 30, 2009 | Samsung LA32A450 32 in. HD-Ready LCD TV
Samsung plasma HPR4272 that had a 4" black vertical line on
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
