Hi I have a 32” walker tv when I plug it in the standby light just keeps flashing can it be fixed or is it for the bin
    Top Expert:
  • Televison & ... Master
  • 53,785 Answers
Open internal fuse or power supply failure
Posted on Aug 23, 2019
SOURCE:
Shmoopy
  • 53 Answers
SOURCE: tv went black and no sound standby light falsh twice and paused and flashed twice again
This indicates a short happened somewhere in the set, causing the set to go into "safe mode" where it won't let itself turn on. Oftentimes it's the convergence board. Depending on what that will cost you, you may want to just replace the set.
Posted on Mar 25, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
welcomejee
  • 10594 Answers
SOURCE: KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Posted on Oct 19, 2009
  • 1684 Answers
SOURCE: emerson lc32oem8 32
The flashing power light indicates a failure in the power supply board of your tv. We should be able to repair the board for our standard rate of $45 plus return shipping. If you are interested in setting up a repair please use the following link to our web site: http://www.ccl-la.com/blog/index.php/service-request-form/ Our normal repair turn around time is 2-3 days.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Mar 08, 2010
Testimonial: "thanks!"
Hi Hi have a toshiba regza 32av555db that was working fine however it will now not turn on, the red standby light is flashing and the green on light flashes also. I have tried a different remote for the...
Problems it is not the tv remote control.This tv have a dying power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 11, 2011 | Toshiba 32AV555DB 32" HDTV-Ready LCD TV
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby time light on and keeps flashing
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
4 fast blinking lights
Oct 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Standby lamp flashes
if the lamp light is flashing,remove the lamp and check it there is 98% of possibility that is bad.
May 19, 2009 | Initial HDTV-320 32 in. LCD TV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Ekse
