Question about Westinghouse Electric L2210NW Monitor
Control buttons on side of L2210NW monitor quit working
The control buttons on my L2210NW monitor will suddenly quit working. To get them to work I have to actually unplug the monitor. That seems to cause another problem. I wait for a while, plug the monitor back in and then the resolution becomes HUGE. I can then use the controls on the side but everything is set right. So then I turn off the monitor with the control buttons since they are working now and then wait, turn it back on and everything goes back to the right size.......
Why does this happen?
3 Suggested Answers
  • 732 Answers
SOURCE: My Westinghouse lcd monitor L2210NW does not turn
anngallant, Yes, I, and all the other "LCD CCFL back-lit monitor" repair guru's on fixya already know what your L2210NW suffers from. You will do a DIY repair to the monitor's SMPS/inverter circuit board, or contract out the work to a qualified electronics technician, or do a cash+trade for a refurbished unit, or trade-in for new monitor. Do NOT attempt the first two "IDEAS" without an extensive speed reading session of the FIXYA profiles of "budmrtn", "buddymc", and other tech's that deal with the very common single cause of black or black and blank screen lcd failure and what it takes to repair/refurbish them! You can also (FYI) do the YOUTUBE thing and view some of the longer and more informative video clips on "LCD monitor disassembly" , "LCD monitor repair". Some are pretty good! Good luck with your unit, whatever route you take. I'm 12fixlouie on fixya.
Posted on Feb 17, 2010
bronk50
  • 27725 Answers
SOURCE: the resolution on my disply suddenly went HUGE and I have tried various resolutions, and the only one that seemd to work is 1699 x 1024 at 76Hz but the size of the font is too small.
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
hope this helps
Posted on Nov 23, 2011
Cant find power button
The monitor control buttons and placement of them which are located on the right side of the monitor with no physical pointers on the front to show what the buttons are. They are way too sensitive even air causing the menu to display on the screen
Feb 17, 2014 | Westinghouse Electric L2210NW Monitor
Screensaver will not turn on after inactivity
This is an adjustment made in the control panel under I believe Display. From there you will have an option for Screen Saver. It should all be in there.
Jan 01, 2013 | HP w1907 LCD Monitor
Westinghouse l2210 montor comes up with color lines on it when i turn on the computer
you should check your video card,and try to upgrade any drivers you have,or go to video card website and check for updates,unplug card from computer,and reinstall reboot and hit F8 button and go into safe mode,go to control panel,hardware manager and look for your video card,clik on plus sign and open it look for update your card or roll back drivers,clik to update and go to file with update and install, then after install, reboot, chek computer video, see if improves if not sounds like video card is done....
Oct 10, 2012 | Westinghouse 22"" L2210NW DVI Widescreen...
L2210NW does not turn on
There are one or two capacitors that are open in the power supply, they often show a bulge at top showing they are leaking.
May 07, 2012 | Westinghouse Electric L2210NW Monitor
Westinghouse L2210NW Monitor Problem My screen is very bright and i believe it to be a hardware issue.(I've tried other monitors on my computer) I have the brightness set to the absolute min and its...
The black splotch your describing sounds very much like something failed on the board and burned the board so now that is a carbon patch that can conduct electric current. With that in mind, I would suggest replacing the board definately
Apr 18, 2017 | Westinghouse Electric L2210NW Monitor
Resolution is horrible and will not ajust
Try this... unplug the power to the monitor. While unplugged, press and hold the power button for 30 seconds. Plug back in and test.
Apr 13, 2011 | Westinghouse Electric L2210NW Monitor
Describe your best resolution for model L2210NW Problem; the letters are blurry and the stuff on screen is so big..
1680 x 1050 should look the crispest with the most on the screen. Hope this helps =] Please rate!
Mar 04, 2011 | Westinghouse Electric L2210NW Monitor
My Westinghouse lcd monitor L2210NW does not turn on everytime. Right now for three days - despite rebooting, etc - I cannot get the screen to display and there are no lights. Power is going to it. Ideas?
Feb 17, 2010 | Westinghouse Electric L2210NW Monitor
L2210nw volume display on screen won't go away
Upgrade to Windows 7. It will take care of this problem immediately
Sep 15, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Can not power up monitor
Hi there
you have a couple of options you can find the website of the manufacture of the monitor and they should have a troubleshooting section or in your manual there may be a number that u can call.. my new dell monitor i had to hold the power button in for 30 seconds
Mar 09, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse Electric L2210NW  Monitor Logo
327 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Clyde Chisale
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
