Question about U-Line 75WC Wine Cooler
Replaced control on u-line 75WC wine cooler now runs constantly
I attempted to bed the sensor in the same spot of the liner where I had removed the old one and am wondering if I did not "bed" it deep enough?
The unit is now running constantly at the lowest setting on the control and is too cold...
Any ideas?
  • 286 Answers
If the sensor of the thermostat is not on the evaporator plate then yes the thermostat will never be satisfied. Because it is not reading air temp only the evaporator plates temp. should be clamped onto the bottom of plate.
Posted on Sep 14, 2009
Testimonial: "Going to check and thanks for the response. I am 99% sure this is the probelm!"
Uline 75WC Wine cooler: light works but fan and compressor do not come on. Wire cnnections are fine.
Does the compressor vibrabte? If not, the PCB isn't working and should be replaced or worst case is your compressor burned out.
Jan 22, 2012 | U-Line 75WC Wine Cooler
Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
Oct 06, 2009 | U-Line 75WC Wine Cooler
Wine fridge thermostat
No pictures, the new one goes in the same as the old one comes out. You have 2 screws on the bottom of the evaporator that holds the sensor in place. Then the sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.
Oct 02, 2009 | U-Line 75WC Wine Cooler
Gets cold but does not shut off.
Check the thermostat to make sure its mounted on the evaporator plate. If its away then the sensor will never satisfy your control, Or you may need to replace the control
Oct 01, 2009 | U-Line 75WC Wine Cooler
I need to replace the metal racks in the u line 75wc refrigerator. They rusted in the back.
To order the racks you will need to order from a parts distributor. To find one in your location just visit U-line. www.u-line.com and under customer service you will see parts locator.
Sep 26, 2009 | U-Line 75WC Wine Cooler
Can you replace a broken glass door in a wine cooler
Only by replacing the door. You can visit www.u-line.com and under customer service you will see parts locator.
Sep 24, 2009 | U-Line 75WC Wine Cooler
I need to replace the door gasket on a U-Line 75WC wine cooler.
Most of the time they send instructions with the new gasket./
Jun 05, 2009 | U-Line 75WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Nov 01, 2008 | U-Line 75WC Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
U-line 75wc
2767-s is the correct thermostat for this. The only thing you will need to do is drillout the liner so the sensor can go in. Use permagum to seal around the hole. It should fit. You may need to bend the terminals 90 degrees.
Jul 23, 2008 | U-Line 75WC Wine Cooler
U-Line 75WC Wine Cooler Logo
564 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
