Question about KitchenAid Refrigerators
Kitchenaid refrigerator ksfcfs25sw lockout button on door stuck & can't unlock so can't get wwater or ice.
SOURCE:
SOURCE: LG Refrigerator water and ice dispenser stuck
We just had this problem and we fixed it by peeling off the soft rubber covering (the part you press the glass against)and then putting it back on. There is a plastic tab beneath that could get stuck if the rubber part gets an air pocket or bent out of shape. This took 2 minutes and worked like a charm.
Posted on Sep 15, 2007
  • 958 Answers
SOURCE: Kitchenaid refrigerator not working
it would not be likely to stuck in defrost mode but my guess would be the compressor is not running. overheated or the condenser is full of dirt. as you said , you can hear fan running, is it inside the ref or outside?..or both?..if that is the case, then it is on freezing mode because the fans would not run on defrost mode..i hope i was able to help..
Posted on Jul 05, 2008
SOURCE: Kitchenaid refrigerator in door water/ice dispensor
Look here.
http://www.fixya.com/support/t219770-kitchenaid_superba_kscs25fkss00
Posted on Aug 02, 2008
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Posted on Feb 02, 2009
SOURCE: Whirlpool refrigerator ice shoot door will not fully close
Replace the whole door chute assembly.
Posted on Feb 11, 2009
Ice dispenser door open. Ice freezes at bottom of bin, rendering the dispenser useless
If the ice door is open that will need to be repaired first before solving the ice melting and stopping the ice auger from moving. What may be happing is the ice door stuck open causing warm moist air from outside the refrigerator to be drawn in covering everything with frost and possibly locking down auger and causing the refrigerator to run continuous. What is the model number found around the fresh food section? Thanks Sea Breeze
Nov 16, 2012 | KitchenAid Architect Series II KSSO42QTX...
I HAVE KITCHENAID SIDE BY SIDE REF. THE OUTLET OF ICE BUCKET FROSTS OVER , NOT ICE.
Hello, Thank You for using FixYa. I will be helping you today. Sometimes ice gets stuck in the ice door causing it to build up frost and ice. When this happens the bucket gets stuck and wont come off. Using a hair dryer and melting it is the way we get them off. This is a common issue. Removing the ice bucket one time a month and running hot water through it and clearing any frost in the chute usually prevents this from happening.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Helo I have a KitchenAid KSBS25FKWHOO which is like this one. My problem is there is a push button for ice cubes or crushed ice and as of now no matter which button i push it gives crushed ice. How can I...
It sounds like your crushed ice flapper might be stuck.
Open the freezer and remove the ice bin by pulling toward you. Dump the ice into a container if you wish to save it.
Turn the bin upside down and look at the opening in the front that the ice drops out. There is a white flapper door that is controlled by a metal rod going all the way to the back of the ice bin. If you move the metal arm up and down from the back you should see the flapper door open and close. Open is for cubed ice and closed causes the cubes to travel through the blades and be crushed.
The most common failure is ice or frost build up around the flapper door that causes it to stick shut and not move to the open or cubed position. You can unthaw by running warm water through it in the sink. Dry completely before returning it to the freezer. Clean out any ice chunks from the chute in the door that might be slowing down ice. That should fix the problem.
Apr 18, 2010 | KitchenAid KSBS25IN Side by Side...
What do do when our KitchenAid ice storage bin is stuck and hard to get out?
if the ice bucket that holds your ice is on the door simple leave the door open for a 15 to 20 minutes and it should melt free if the ice bin is in the freezer the same should work but it may take a little longer
Apr 03, 2010 | KitchenAid KSRG25FK Side by Side...
Ice maker stopped working. Red light is blinking.
  • That means no flow of water to icemaker. So check the solenoid valve paddle is stuck/jammed due to a fault in the Valve; replace valve.
  • accumulation of frost in the water supply tube &/or blockage
  • defrost button stuck
push the door close button with your thumb, insert the ice tray, any water flowing into the icemaker??----------- observe the position of the paddle & don't forget to check the defrost button is not engaged.......sodeep
Oct 26, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
NO ICE
Check this first,
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
ice and water dispensers. To turn off the ice maker, see “Ice
Maker & Storage Bin.”
 Press and hold LOCKOUT for 3 seconds to lock the
dispenser.
 Press and hold LOCKOUT a second time to unlock the dispenser.
Let me know if this helped, Sea Breeze
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker
MAKE SURE THE DOOR CLOSER IN THE DISPENSER IS OPERATING PROPERLY. IT SHOULD SLOWLY CLOSE THE DOOR AFTER YOU STOP PRESSING ON THE PADDLE.
EITHER THE DOOR IS CLOSING TOO QUICKLY, NOT AT ALL, OR THE DISPENSER IS RUNNING AFTER THE DOOR HAS CLOSED. CHECK THE OPERATIONS OF EACH OF THESE AND SEE IF YOU CAN TELL WHICH.
Apr 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Look here.
Jan 07, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
29 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
