My boiler is diesel but it wase set in gas when I set up T6 thermostat. How can I change it to diesel from gas?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Heating & Co... Master
  • 572 Answers
It doesn't matter. It will still work ,diesel is still consider a gas
Posted on Aug 24, 2019
SOURCE:
I replaced T6 Pro thermostat but heat is not working why
did you configure the heat
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jan 07, 2018 | Heating & Cooling
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Trevitherm shower use trips out combi boiler
The boiler may be over gassed or have the incorrect low / high pressures set. Recommend a service by a gas safe registered engineer
Mar 04, 2014 | Samsung Digimax D73 Digital Camera
Symptoms bad thermostat
how to replace a water pump in a 2010 jaguar fx
Jan 04, 2014 | Measuring Tools & Sensors
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
My boiler will not fire up the pilot light is on, the thermostat clicks when asking for heat but boiler will not go on. What could be the problem ?
Best case, the gas selector switch is set to the pilot position. Rotate it to the full open position to allow the boiler to fire. If it is already in the normal operating position, you will probably need to replace the gas valve.
Oct 03, 2009 | Water Heaters
Boiler is not firing up
is there a toime delay on the thermostat ? And when you installled it did you see a section that says installers mode settings? You can get good information from the manufacture web site for the setting for the type heat and application that you are using the thermostat to control. Good Luck
Jan 06, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Oct 20, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Installing a boiler
Set the Miller to turn on at 7-10 degrees lower than your wood boiler. Make sure the Miler works by turning up the t-stat 10 degrees higher than room temperature first.
Sep 13, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
