Question about D-Link DIR-615 Wireless Router
Sitecom WL-330 range extender with dlink dir-615- unable to use
How do i setup sitecom WL-330 range extender with dlink dir-615 normal manual setup ends that i can connect wireless to extender but not acces any site nor config utility in any way please help!
  • 10 Answers
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Posted on Sep 13, 2009
Testimonial: "tanks v. much for answer, i'll try it right away"
  • AgeH Mar 16, 2011
    I had a problem with the Sitecom 300N extender working after setup but then losing full connectivity to the internet some time later for no apparent reason, even though the primary D-Link router was still working and broadcasting fine. The solution for me was to un-check the box in the Sitecom wireless setup for 'auto-scan', because that was changing the channel each time it was rebooted...so the 300N couldn't pick it up any more! I also needed to make sure that both devices were using the same channel number.
    So...
    1) Lock the main router onto a fixed channel
    2) Configure the extender to pick it up
    3) Set the extender channel to match the primary one
    That worked for me!
Computer says that the pin number is incorrect, please use no. on modem. modem nuber keeps coming up incorrect
You should refer to your wireless router setup manual for pin number....
you can also prefer this link to search modem pin no-http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-615-wireless-n-300-router
Sep 03, 2012 | D-Link DIR-615 Wireless Router
My instruction manual is in Chinese, i am using a mac and i cannot connect wirelessly to the internet, I have a DIR-605 router.
well here is a link to obtain the manual http://www.dlink.com/products/?pid=DIR-615
you need to select Support Resources Tab and choose the revision type you have. then you select product manual. One example is this one "DIR-615 no rev. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | D-Link DIR-615 Wireless Router
How do i set up security on router
Here is a link to show you how to setup security on your router, it is the manual to the peace of equipment good luck. Copy and paste adderess into address bar.
ftp://ftp10.dlink.com/pdfs/products/DIR-615/DIR-615_ds.pdf
Feb 17, 2011 | D-Link DIR-615 Wireless Router
How do I reinstall a dlink 615 modem. mcafee syys a trojan has been identified each time I try the install disc. can I install without the disc and how?
I can help you with your DLink DIR-615 router problem.
You don't really need to run anything from the disc to install a router - there is no setup program on the dlink cd you are required to run. Routers operate independently of the computers they are plugged into.
The most useful thing on that disc is the user manual, which you can download direct from DLink here. Any other bits and pieces that are on the 'installation CD' are also available from their webpage.
I hope that helps.
Aug 28, 2010 | D-Link DIR-615 Wireless Router
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Jan 12, 2010 | D-Link AirPlus G DWL-G710 Wireless Range...
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
D-Link DIR-615 Wireless Router Logo
7,837 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
