Question about Samsung RB2155 Bottom Freezer Refrigerator
SAMSUNG REFRIGERATOR LEAKS AT WATER FILTER
Samsung French Door w/Water & Ice dispenser: Apparently this has been happening for a while, unbeknownst to us. Water is dripping from water filter, down the back wall of the fridge, and collecting under the bottom, fridge width pull-out drawer. This has rusted some screws & caused a mess.
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
  • 120 Answers
SOURCE: getting rust on the water dispenser door
if your door is rusting ,its time to move on and buy another unit.
Posted on Oct 05, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Water will not dispense--fairly new filter
Are you sure about that model number because I have the service manual for a RS265AA if you like. The water valve can be tested ao back with a multi-meter and should show 120 volts or your home voltage when someone presses the dispense water switch. If yes the voltage is present the water control valve is defective and will need replaced.Double check your model number because there are no Samsung refrigerators with the RF2 prefix RS2 is Samsung prefix. Let me know, what you find, Sea Breeze
Posted on Dec 12, 2009
  • 949 Answers
SOURCE: water dripping from freezer area down in refrigera...
This is most likely due to the defrost drain being restricted, see the link below and let me know if it helps.
Defrost Drain
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: I have an ge french
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Posted on Sep 27, 2010
Samsung French door ice maker
Sounds like you are getting to much water or the sensor is not Sensing proper temp
Apr 02, 2016 | Samsung Refrigerators
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Why is my Samsung french door/freezer not working
It is very rare to have a freon leak. It is possible but there are there are things that can cause the refrigerator not to get cold. Is the compressor running. Are the fans running. Is the freezer or refrigerator coils blocked with ice. Usually freon is the last place i look.
Jul 23, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Freezer apparently wont defrost because it has that dry ice look. freezing fine
some times our equipment need rest !!! remove your food , unplug for at least two days, clean inside.after two days plug back
Mar 12, 2012 | Maytag MFD2560HES Bottom Freezer French...
Sam Sung French Door Refrigerator RF267 After one month, water dispensing slow, small ice cubes, cloudy water. What is the solution?
It sounds like the water filter needs changed. Yes I see It's only been one month. Also make sure you have good water pressure to the frig.
I hope this helps.
Aug 23, 2010 | Samsung RF265AA Bottom Freezer French Door...
Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Samsung RB2155 Bottom Freezer Refrigerator Logo
675 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
