Oxc18a0406 hi same as all on here inksystem failur printer hp 3310 what to do i have try many time the reste but no chance not working
  • 14 Answers
SOURCE: Ink System failure error message
Refer to NateOcean's solution at http://www.fixya.com/support/t297123-ink_system_failure. My Photosmart 3310 also had the loose plastic gear problem at the ink pump. Seems that all the HP inkjet printers use the same mechanical system and that gear can just slip off over time. My printer was two years old. NOTE: You have to remove the black and white gear with belt to replace the white gear that slips off. Remove the belt first by slackening the tensioner pulleys. Then there is a very small white clip against the axel that prevents the large gear from being pulled off - lift the white tab carefully with something sharp and the gear should slip off easily. The culprit gear then just pushes onto the hex shaft.
This operation should be possible by just opening up the left hand side of the printer.
Posted on May 01, 2008
  • 333 Answers
SOURCE: need software for 3110 photosmart all in one hp printer
All the drivers for this printer are here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=439486&lc=en&cc=us&dlc=en&submit.y=6&submit.x=4&lang=en&cc=us&y=7&x=9
Don't forget to leave feedback, 'fixya' if it what you were looking for!
Posted on May 06, 2008
rcsnet
  • 15 Answers
SOURCE: print head proplems on the hp photosmart 3310
ok, if you are using old cartriges, might want to try some rubbing alcohol on a tissue. This has worked on a number of cartriges in the past when i start getting missing pins. it lubricates the holes so in can flow again.
Take a q-tip and do the same if there's any kind of print head, but most print heads these days are built into the cartrige.
Posted on Mar 21, 2009
SOURCE: hp 3310 photosmart - ink system failure 0xc19a0013
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
If this doesn't work let me know.
Posted on Dec 20, 2009
  • 159 Answers
SOURCE: have a hp 3310 it says ink system failure error
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Posted on Mar 15, 2010
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
My printer does not work cause oxc18a0406 . what
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 22, 2010 | HP Photosmart C5180 All-In-One InkJet...
Printer error oxc18a0406
Kindly do the following steps to resolve the issue:
A. Press and hold the "*" key.
B. Press the "#" key and release both keys.Display should say "Enter Special Key Combo"
C. Press and release in sequence the "1", "2" and "3" buttons.
D. Press and release the right arrow button until the display says "System Configuration Menu".
E. Press and release the "OK" button.
F. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status".
G. Press and release the "OK" button.
H. Display should say "Hardware failure status: Clear. Press OK to clear".
I. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
J. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
K. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
L. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
M. urn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. If it didn't it's ok.
N. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Hope this helps.
Thank you for using FixYa.
Feb 06, 2010 | HP Photosmart 8250 InkJet Printer
Hp photosmart 3310 error oxc18a0101ink system failure
Try unplugging the printer to see if that helps. If that doesn't do it sounds like your printer is dead.
Dec 27, 2009 | HP Photosmart 3310 All-In-One InkJet...
Error code Oxc18a0206 ink system failure
I had this same exact problem. Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons.
I had to go through multiple tries of the solution above. I turned it back on, it shut off and I turned it back on again. I tried to print something and sure enough, it did a maintenance cycle and it works again.
This did not work the first time but after 3-4 times of doing both, TA DAH, it went through a lengthy maintenance cycle and then started working. Persistence paid off
Jan 22, 2009 | HP Photosmart 3310 Printer
Will not print Magenta
it seems that your cartridge nozzle is dryed out u can try to clean via the hp tool software or via the menu on your printer if that not works try a new one and if that is not working than call hp for support
Dec 17, 2008 | HP Photosmart 3310 Printer
Hp photosmart 3313 all in one
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support. If you need their contact info I can give it to you.
Thanks,
Lee
Jun 17, 2008 | HP Photosmart 3210 Printer
Printer problems for HP Photosmart 3310
Try running antispyware and virus program to eliminate this, housecall is online, thorough and free. It removes it too. Try and see if updating the actual drivers help off HP website. Check settings to see if it is not accidentally set to only print test page or to work offline or similar, uncheck tabs if they are.
Nov 10, 2006 | HP Photosmart 3310 Printer
42 people viewed this question
k24674
