Question about Motorola Mobility Q9h Smartphone
My Motorola Q9h Smartphone locks up at the Windows Mobile Screen. I've tried taking the battery out and putting it back in. I've been trying to get it to reboot.
My motorola q9h cannot restart, when i press on button it just shows the motorola logo but cant open.
Remove the battery and hold down the power button for at least 30 seconds. This will reset the circuits. Put the battery back in and turn the phone back on. If it still hangs and doesn't load you may have a corrupt boot file. In this case you'll want to contact Motorola. Good luck!
Mar 03, 2011 | Motorola Mobility Q9h Smartphone
How to read pdf files in Motorola Q9h?
download the microsoft mobile office suite
Feb 15, 2011 | Motorola Mobility Q9h Smartphone
My motoq 9h is not booting up and the phone is stuck on windows mobile screen
Take out the battery for 2 minutes, then put it back in.
You are going to need to do a Master Reset which resets the phone to factory settings. This will erase all data entered into the phone, your contacts, calendar, etc., but will leave the SD card intact.
Hold down the center button of the navigational pad, and power button at the same time which will trigger the master reset. Follow the directions on the screen.
Once you've performed the master reset, goto the Motorola site to do a full update to your phone. This, in my experience, will eliminate the freezing problems associated with the Motorola Q9M, Q9c, Q9h, etc.
Good Luck!
Aug 02, 2009 | Motorola Mobility Q9m Smartphone
How to unlocked motorola Q9h
my mobile is moto q. i have lost my password
Apr 21, 2009 | Motorola Mobility Q9h Smartphone
BSNL 3G INTERNET SETTING FOR MOTOROLA Q9H
Moto q9 phones don't havea the capability to use 3G internet yet. A software update will be released soon. Contact your service provider for details on when they will be releasing their update.
Mar 31, 2009 | Motorola Mobility Q9h Smartphone
Screen freezing on my moto q9h
You'll have to remove the battery. I had this similar problem with my Moto q9c. I ended up replacing the battery and haven't had the problem since.
Mar 24, 2009 | Motorola Mobility Q9m Smartphone
Motorola q9c smartphone is frozen on windows mobile screen. this happed when i updgraded and had a new phone activated. is there any way to unfreeze the phone. have tried teh soft reset with battery with...
master reset the phone by hold the center key and the power, then follow onscreen instructions, let it sit on the windows mobile screen, before you master reset try turning the phone off, and taking out the memory card, then turn back on, if same thing happens....do the master reset
Dec 29, 2008 | Motorola Mobility Q9m Smartphone
Motorola Q9m frozen how can I get my contacts
I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
This happened all the time until I went to the Motorola site and did full phone update ( http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
Oct 17, 2008 | Motorola Mobility Q9m Smartphone
Motorola Mobility Q9h Smartphone Logo
148 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
