Question about Refrigerators
Igloo ice maker is making ice but it's melting before the next batch drops. Its full of water has been cleaned had to reset it because it said it was full but no ice was made.
SOURCE:
watugot
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
  • 1122 Answers
SOURCE: Kenmore 253.54703405 ice maker does not reset
a gear under the cover turns the arm,i think you should find a appliance part store in your area and replace,around $50 for brand new one,thanks-mike
Posted on Jul 12, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. [email protected] click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
Posted on Apr 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Posted on Jul 24, 2009
Igloo countertop ice machine says tray is full when empty and will not make ice
Hi I had the exact same issue after about a year of running my igloo ice maker non stop. To fix it I held in the on/off button and select button at the same time for about 30 sec and TADA!! Back to making ice.
If that doesn't work I've also read to leave machine unplugged for 6 hrs and then hold in on/off button for 10 seconds. Good Luck!!!!
Sep 13, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do I clean my igloo ice maker
Igloo Ice Maker ICE102-WHITE - Kitchen Appliances Manuals
kitchen.manualsonline.com > ... > Igloo Ice Maker
Igloo ICE102-WHITE Ice Maker User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Igloo Portable Ice Maker Review - YouTube
? 4:02
https://www.youtube.com/watch?v=893Cs66veK0
Jan 3, 2014 - Uploaded by TheVirginiaStew
The Igloo Portable Ice Maker, Model is the ICE 102C Silver and it is great. It can go ... Main thing is to use good ...
Jan 19, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How to clean igloo portable ice maker
Maybe scaling has occured, get descaling chemical to clean it. Also remember to remove the dust accumulate at the condenser..
Oct 11, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My portable ice maker is not making ice, when turned on it shows ice full, but there is no ice in it. Any advice?
it seems the sensor is jammed or malfunctioning, fooling the control section and keeping the machine from working.
I don't know the machine but the sensor detecting the full ice section is either mechanical or a thermistor (electronic). Locate the sensor and make sure it is in position to sense or simply messing with it may make it work again.
Igloo may have a troubleshooting section in their website.
Oct 04, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Igloo ICE102 FULL sensor is stuck on
Hello If the ice maker light is stuck on full, most likely the Infrared sensor may have shorted out due to water seeping into either the infrared emitter or receiver or both. It is an easy fix. It is best to replace both the infrared emitter and receiver diodes. You can find 2 terminal/lead infrared emitter and receiver diodes on ebay or your local electronics store for cheap. Please ask the guys at the store that they are spectrally matched to each other. You just need to remove the old ones inside the ice maker and replace them with the new ones from ebay by soldering them on. If you cannot do this then best to take it to a local electrical store to get them to replace these for you.
Feb 01, 2013 | Refrigerators
Jul 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
