Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Power Switch on Side of Toshiba Regza 37XV635DB Broken - Solved
I just turned on my TV, which I have had for about 3 weeks and has been working fine. It would not come on, so I pressed it a few more times and I heard a rattling noise as something fell. I opened up the TV by taking all the screws labelled with an arrow on the back out.
I found that the contact pad between the exterior button and the switch had snapped off. I have recovered this and have glued it back in place. This is an inherant design fault; If you push the button all the way in, it will over-strain the contact pad. I had obviously done this repeatedly and it snapped.
Here is a very crude diagram of what is happening:
'''''''''' [_______
1 2 3
1 = Back of button
2 = contact pad
3 = Switch
If 1 goes in too far, it will snap 2 off.
To prevent this, Just push the button in until you hear the switch click. If you do break it, the solutions are:
1) Do what I have done
2) Do what I have done and hacksaw a small length (about 2mm in my case) from the back of the button so that contact pad cannot be bent.
3) Get it fixed by a professional preferrably under warranty.
    Problem Solver:
  • 11 Answers
Soultion 4) Toshiba provide excellent customer service, if this happens simply contact the help line/support supplied with your TV - they will advise you to take the TV back to store for an exchange.
Its not advisable to take the back off any electrical equipment unless your are a qualified electrician.
Posted on Sep 13, 2009
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I Have a Toshiba Regza XV55, purchased in December 2008 and the manual on/off switch has been temperamental for a few weeks until last night when it stopped working completely and now we can't turn the TV...
I suspect that the switch has a fractured solder connection or that it went bad all together..The only real way to check the switch is to take the tv apart and check it with an volt ohm milliameter. If it feels like it is not clicking then most likely the switch is bad now. But if it feels like it is working correctly it is most likely a fractured solder connection and needs to be re-soldered, The only other variable would be that the connector is broken or that it just came unhooked. That would be an easy fix. Good luck. HDTV GURU JAY.....
Mar 24, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Am having the same problems. The TV is on standby (red light on front) but wont turn on from the remote or from the side of the set. This can last 1 or 2 days, then it works fine again for another week,...
There is a problem with the power switch board,there might be short in the IC Unit , you might have to change it. get it serviced by a TV electrician soon before the board gets damaged.
thanks for rating good luck
Feb 08, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
I have a Toshiba regza LCD 32AV600 TV set. The remote is not able to turn on the TV (only manually from the side of the screen). Other functions of the remote work fine. I tried using a different remote...
Tries reset the tv back to factory setting and the cable box too by unplug,replug it back an hour later.Go to tv menu,go to PICTURE,go down to reset,so the Tuner board it reset it back to the factory setting.This should solved ur problems,not than the tv tuner board that recieve the bracasting signal board have probems.
Jun 02, 2010 | Toshiba 32AV600E 32 in. TV
Problems turning on
The tv power supply board have problems,it the board with the a/c power cord plug into it.That the tv power supply board it dying.Replaced the power supply board will solved this.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Toshiba REGZA 47HL167 TV
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Televison & Video
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
2,226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
