Question about GE Refrigerators
How do I remove the escutcheon on a 2015 GE refrigerator. I need to replace the ice flap. Thank you.
Model: GSS25SGMDBS
    Problem Solver:
  • 18 Answers
Look up in to the area of ice flap no screws grab with hands at bottom pull up and out remove 4 screws for ice funnel replace flap
Posted on Aug 28, 2019
SOURCE:
  • 58 Answers
SOURCE: GE Refrigerator
first, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Posted on Sep 26, 2008
  • 1122 Answers
SOURCE: Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Posted on Apr 14, 2009
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
aasc
  • 1606 Answers
SOURCE: GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Posted on Jul 11, 2009
allbrands
  • 600 Answers
SOURCE: Whirlpool Refrigerator Model #ED5LHEXTD00 ice
Hello, Thank You for using FixYa. I will be helping you today.If the door is missing it will melt the ice and frost up the freezer or temp loss,The part number is 2180353 if you need all the parts its 8201649
Thank You and please rate my answer if it was helpful..
Posted on Jun 11, 2011
How do I remove the escutcheon around the water/ice dispenser in the door?
Click on this link to find model specific help , parts and video help listed with the parts. Bring your model number good luck: http://www.repairclinic.com/RepairHelp/Appliance-Repair-Help-Lawn-Mower-Repair-Help-Small-Engine-Repair-Help
Sep 14, 2015 | Refrigerators
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
Ice dispensor flap is little warped.
the number for ge parts service is 1-877-959-8688. make sure you have the model # and serial number. if you don't have a manuel or if you have one that covers more than one model in it than you have to look for a little black most likely silver plate wich will have that info on it. if it's not on the inside or front of fridge anywhere you will have to pull it out from the wall because it will be on the back of it. hope i helped you.
Aug 15, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Profile Ice flap is broken
The part number you need is WR62X10055 . This is the sokenoid and plunger which operates the flap . They tend to rust badly , keeping the flap from opening/closing . With a small screwdriver , pry the control panel ( from the bottom only ) outwards . This panel is the push buttons for crush , cube , water . Once removed , there are 4 screws , one on each corner of the white housing . Unplug the 3 plugs on the control panel first . Remove the 4 screws and slide out the housing . The solenoid and plunger are at the top right , held on by 3 screws . Replace solenoid AND plunger , and reassemble in reverse . Also , remove the top freezer door hinge cover to access the plug which should be unplugged first . After reassembling dispensor , dont forget to plug the plug back in .
Aug 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
