Question about Garden
575xp piston and crank blow why have not used the 575 to much.It just never worked wel and 570xp have same problem are they dud masjiens
    Brigadier General:
  • 4,088 Answers
If there are bearing and seal problems on the crankshaft, plus damage to piston and rings, you are looking at several hundred dollars if you farm the job out to a shop. Is the saw worth more than that? It sounds like the engine was run without proper oil in the fuel at one point in it's life.
Posted on Sep 13, 2009
How mutch oil for a 2.3 auf engine
You must add 5 1/2 quarts of oil to possibly 6 quarts to it this is very much required but I'm positive only 5 quarts do not over fill the motor it can blow the engine or burn the piston rings because either too much or less is added
Mar 23, 2014 | 1993 Volkswagen Caravelle
I used compressor 3 wks ago and worked great.Now will not compress air above 25 psi.changed regulator OK,removed air intake filter,it has suchion.removed outlet tube,bloweds air.Oil in site glass.I did...
Mike:
If you have air blowing out of the oil filler cap, I would suspect that the piston rings are shot. The piston rings are supposed to keep the compressed air above the piston, and air seems to be leaking past the piston rings into the crank case.
Sep 17, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Virago blowing out through air filter
Will, let me tell you the "Old school" way to fix this.(1) Remove all of the spark plugs. (2) Disconnect the fuel lines. (3) Pour light weight oil directly into the heads.(I know, sounds weird) (4) Crank Crank Crank Crank. Until the engine turns smoothly. If the valves were stuck, this should cure it! (5) Blow the oil out by the compression of the engine cranking. (6) Pour alcalhol into the cylindars to clean the oil out of the top of the pistons.(Starting fluid also works well) (7) Again, Blow it out using the compression of the engine. (8) Put everything back together and fire it up! NOTE!!!! Any time you know you are going to store anything with an internal combustion engine, treat the engine in the same way, by pouring oil into, and onto the pistons directly. This prevents seize ups, and helps to preserve oil seals. ^^
Jan 11, 2013 | 1994 Yamaha XV 535 Virago DX
97 concord blowing all oil out of crank case front of moter
Possible broken piston ring or hole in a piston
Dec 09, 2012 | 1997 Chrysler Concorde
Only 3 pistons firing
Out of how many?
Dec 26, 2011 | Cars & Trucks
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
I want to replace the head and piston on my Husqvanna 575 XP chain saw : 6 years old : with a new Husqvarna head and piston from a HUsqvarna 576 XP kit will it fit.
here is web site
http://www.partstree.com/parts/?lc=husqvarna&mn=576+XP+EPA+%282009-01%29&dn=90_07_0045
576 xp 2009 parts should fit on 575 xp to s/n up to 081700001
but do x ref on parts 1st before purchase
these were on the 2009 576 - service update #1 in that list
check stroke and piston sizes carefully
cheers
Aug 05, 2010 | Husqvarna Garden
How to replace a oilker on a 575 husqvarna
The video is a fantastic guide. R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Jan 23, 2010 | Husqvarna Garden
How to line up no1 cylinder on TDC on 1998 Daewoo Lanos SOHC. Have got the cam sprocket on its correct marking, but the crankshaft pulley has only pick up coil on it no timing mark Thanks John Gold Coast...
Ibring piston to compression stroke. Apiece of tissue in the plug hole will blow out and then turn crank by hand until the piston is at the top. There should be timing mstks on the crankshaft pully.no timing marks? Then ease the crank around untill the piston starts to go done you can feel the piston with a straw. Note, the crank pully keyway more than like be at the 12 oclock position. good luck
Jun 09, 2009 | 1999 Daewoo Lanos
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
