Question about HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges missing'!
  • Sean Jack Dec 12, 2007
    Hardware issue - reassembly of cartridge was incorrect. The spring array on the carrige assembly that hold the cartridge assemblies firmly in place was incorrectly assembled. Thus the cartridges were not held tight and thus not making contact with the cartridge ribbon sensor.
  • mdarlenecox Jul 28, 2008
    I am getting a 'Cartridges Missing' error I have not disasembled anything we turned it on and geave the error. I have tried using a new cartridge and that didn't work.
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Posted on Apr 07, 2011
    Problem Solver:
  • 9 Answers
Please Check the ribbon if it is placed correctly
Posted on Dec 12, 2007
  • 89 Answers
It sounds like the data ribbions were not put back in correctly. You should try reseating them.
750c plus was turned off and now says printer cartridges missing
Pull out the cartridges, turn the plotter on and install the ink cartridges one at a time - making sure each one is recognized. One of them may have gotten a power surge and had the electronics burned out - - replace that cartridge with a new one.
Mar 28, 2013 | HP DesignJet 750c plus InkJet Printer
Hp 750c Designjet plotter system error 010030 00070b20
This is a problem with one of three
  • Trailing cable
  • main PCA
  • carriage assembly
Jul 09, 2012 | HP DesignJet 750c plus InkJet Printer
HP 750C Moved across country, bought a new iMac. Forgot how to set up plotter settings so the mac can find it. on the network. I remember having to make changes on the plotter, but can't remember what...
Hello, the plotter should be seen in your print and fax preferences (apple menu, system preferences, print and fax): In the print and fax preferences panel, you can click on "+" at the bottom left of the window, you should see your plotter appear in the window, and click on the "add" button Best regards
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
DesignJet 750c Plus System Error 040502
The bad news is that this seems to be a fatal error of the main board. The only time I have had a similar error is when the carrage motor shorted out and blew the main board. This probably did not happen in your case but something appears to have taken the board out. The main board is speculation, but I think I am correct, sorry, Dave
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Allignement error HP 750C
One or all of the cartriges is not working. If you press continue, and do a color cartrige alignment page again, you will see what cartrige is not working properly
Feb 06, 2009 | HP DesignJet 750c plus InkJet Printer
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
1,046 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
