Question about Toshiba Computers & Internet
Toshiba 62MX196 DLP projector On Full XVG VESA res. 1360 x 768 picture twisted, curved, bad sync.
Use projector PC input 15-pin D-sub port. After booting signal pass to XVG VESA resolution 1360 x 768 then picture twisted, curved bad sync. Arcade machine sega Yellow Lindbergh video game computer If I use a LCD monitor instead of DLP projector image is good.
    Novelist:
  • 207 Answers
Consult the projector user guide for setup and adjustment. Look for a "Default" or "Restore default" option. Otherwise, manually follow the steps. to square up the picture.
Posted on Aug 23, 2019
Testimonial: "Very helpfull Press Menu 1- Go to Setup 2- PC setting 3- Clock phase +2 4- Sampling clock +15 Work great Thanks Gaucherre"
SOURCE:
SOURCE: Connect Laptop Computer to TV
google this
ITV-900 pc to tv converter
Posted on May 21, 2008
dsacco86
  • 1077 Answers
SOURCE: Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
Posted on May 29, 2009
projdoc
  • 2239 Answers
SOURCE: Video input won't accept signal.
if the video signal is HD, the projector can't read it.
Posted on Aug 04, 2009
Testimonial: "Thanks. Hopefully this will help others. Since the input was not HD, it didn't solve my issue, however."
  • 95 Answers
SOURCE: Video input: 2 D-sub No signal /Video input 1 DVI-D No signal
Below is a link that may help you...Good luck http://www.techspot.com/vb/all/windows/t-35070-DVI-to-DVI--No-Signal-on-LCD.html
Posted on Apr 06, 2010
SOURCE: no signal for my lcd projector
Have you tried replacing the projector lamp? This company has all the lamps in the world: www.myprojectorlamps.com
Posted on Apr 11, 2012
Black and white picture and white spots
if it is the color wheel issue, you can replace it, i have this acer X1160 color wheel, if you need please contact me
Jul 11, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
DLP projector repair with picture
Is the bulb bad this type of projector can go thru bulbs if bulb was touched with figures or jolted in any way.always put bulb in wearing latex gloves to keep oils from skin getting on it.
Jan 24, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Hi my laptop went in for repair and they said it cant be fixed as the vga isnt working? what is this and could it be solved
A Video Graphics Array (VGA) connector is a three-row 15-pin DE-15 connector. The 15-pin VGA connector is found on many video cards, computer monitors, and some high definition television sets. On laptop computers or other small devices, a mini-VGA port is sometimes used in place of the full-sized VGA connector.
DE-15 is also conventionally called RGB connector, D-sub 15, mini sub D15, mini D15, DB-15, HDB-15, HD-15 or HD15 (High Density, to distinguish it from the older and less flexible DE-9 connector used on older VGA cards, which has the same shell size but only two rows of pins).
VGA connectors and cables carry analog component RGBHV (red, green, blue, horizontal sync, vertical sync) video signals, and VESA Display Data Channel (VESA DDC) data. In the original version of DE-15 pinout, one pin was keyed and 4 pins carried Monitor ID bits which were rarely used; VESA DDC redefined some of these pins and replaced the key pin with +5 V DC power supply.
the only solution for that is to replace your vga.
May 31, 2011 | Computers & Internet
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
How do I change the input from the DVI-I input to the 15
I found the online manual and followed the instructions to set to "auto" input. Everything works fine.
It had been a discouraging ordeal trying to locate a new DVI cable (which came with the projector)
and as it turns out the 15 pin cable works fine. Thank you.
Rick
Jun 11, 2009 | Sanyo PLC XU50 Multimedia Projector
No video from computer input port
Hi there
As far as I know this specific model requires comes out with a convertor box - are you using it ?
Mar 18, 2008 | InFocus LP 755 Multimedia Projector
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
