GE Eterna Dryer Mod: EED2000AOWW Dryer continues to exert heat from the back panel continuously even after use. We have been unplugging after use due to concerns.
  • 1 more comment
  • rgsherrill Sep 13, 2009
    I pulled the model off the inside door. Its about 9 years old. It's electric.
    I'll take it apart if you can guide me.
    Thanks,
    The model number came from the unit inside the door.
    Where would I look for the burning coil? It's electric.
    Thanks,
  • rgsherrill Sep 14, 2009
    Very helpful. Good directions on what is wrong and how to get to.
  • 313 Answers
A couple of questions:
  1. Are you sure on the model number my surch comes up that it is not?
  2. Is it gas or electric
  3. are you comfortable with taking the dryer apart?
Basically I need to know if the Pilot light (Gas) or heater coil (Electric) is still burning or glowing while your dryer is off.
Leave me a comment and let me know...
Posted on Sep 13, 2009
  • 1 more comment
  • Randy Trent
    Randy Trent Sep 13, 2009
    Can you give me the model number and let me know if you can see the light from the burner ater the dryer is off.
    Information will help me help you.
  • Randy Trent
    The heating element (heater coil) is behind the drum. Behind the back panel.
    If you take out the scews in the front of the dryer. You will be able to take off the top and see down the back where the Heating element is.
    You can buy the repair manual and the link below.
    http://www.repairclinic.com/GE-Dryer-Par...
    It will be there next day after you order it.
    The manual help you take it apart and fix any future problems you may have.
  • Randy Trent
    A bad dryer thermostat can fail in such a way that the heat is "stuck" on and won't turn off no matter what setting you put on the dryer. This is a dangerous condition as a dryer can overheat and create a fire hazard. You will need replacement dryer parts, namely a replacement thermostat. Use the same brand that corresponds to your dryer, whether you need Kenmore dryer parts, GE dryer parts, Maytag dryer parts, and etc. Dryers have more than one thermostat, but fortunately many models have them grouped together. These dryer parts are often located in the vent line, under your lint trap or on the housing of the blower. If you don't feel like testing them all with an ohmmeter, there is nothing wrong with replacing them all and see what happens.
    That is going to be your answer.
Not Drying No Heat
Test for these first:
First of all, see if you have good voltage supply on the socket on which it is powered too.
(1) All venting is clear of lint, even disconnected from back of dryer.
(2) Breaker in house is not tripped. Cycle the breakers off and back on to make sure.
(3) Test continuity on all thermostats and thermal fuses, all have to measure 0 ohms when wires are disonnected and dryer unplugged. We tested the HiLimit Thermostat, Safety Thermostat, and Thermal fuse mounted to the heating element housing, all should have continuity. Also measure the two thermostats located near the exhaust duct in the rear of the dryer, get 0 ohms as well.
(4) Disconnect wires from heating elements. Test continuity from each terminal to the metal cage to make sure none of the elements were grounded. Good if theres no continuity there.
(5) Disconnect wires from heating elements. Test resistance between double coil and inner/outer coil. Each should measure around 19 ohms.
(6) Test the dryer temperature switch by removing wire from terminal 15, then took a reading between terminal 15 and terminal 16, should get 0 ohms there.
(7)Test the dryer timer by first setting the timer to 60 minutes. then remove the wire from terminal A. We then took a reading between terminal A and terminal B, and should get 0 ohms. then keet the leads on those two terminals and rotate the timer and had continuity throughout the 70 minute cycle.
Apr 14, 2008 | GE Profile Harmony DPGT750EC Electric...
Hi I have a ge adora dryer that won't heat up
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 26, 2011 | GE Dryers
Dryer is no longer heating? Could it be a heating
If it will run, but does not heat......Yes, it is most likely a heater or thermostat failure. Most dryers have more than one thermostat. You can find out which one is faulty by measuring continuity with a meter. At room temperature all thermostats will have continuity between the two terminals. Make sure to unplug the power cord before opening any machine!!
Apr 06, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Have a Kenmore Elite Mod#11062932100 It will run but has no heat. The heating element appears to have continuity. What can it be and haow do I test for them?
on the element housing u have overheat safeties they r round unplug unit and take wires off safeties and check for continuity thru each one also unhook dryer vent on back and see if this clears up problem if the hose being off fixes it u have a restriction or a kinked hose hope this helps
Feb 24, 2010 | Kenmore 64902 Electric Dryer
Dryer continues to exert heat from the back panel hours after use. We have been unplugging after use due to concerns.
Ths sounds like a grounded heating element. Upplug the machine. There is a danger of electical current flowing throught the body of the machine. The heating element should be checked using a multimeter. Make sure the heating element is not grounded to the body of the machine. Hope this helped and best wishes.
Sep 13, 2009 | Washing Machines
My GE DHDSR46EE1WW Dryers heating coil won't shut off...ever!
I think your heating coil may have broken loose or sagged down so that it may be shorting itself against the shroud. The thermal fuse would not allow the dryer to heat at all, and a hi limit error would cause the thermal fuse to blow.
Jun 14, 2009 | Dryers
Dryer won't heat.
Hi, THe heating element is located in the back of your dryer. UNPLUG the dryer. Remove the back panel and you will see the element on the right hand side. If you have an ohms meter, check continuity on all the thermostats and the element. If any of them have no continuity, it will need replaced. Please let me know if I can assist you further.
Thanks
Vic
May 16, 2009 | Whirlpool LER5636P Electric Dryer
GE dryer barely heating
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Jan 03, 2009 | GE DVLR223 Dryers
My GE Profile gas cook top was just cleaned. Now the starter keeps clicking and the only way we can stop it is to unplug the appliance. As soon as we plug it back in it continues to click.
if you have a multi meter you can figure this out. check to see if you have continuity through the switches while they are in the off position and unplugged from the spark mod. if you do replace the wire harness. if you dont replace the spark mod.
Dec 05, 2008 | Cooktops
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
