Question about Logitech Harmony 890 LCD Remote Control
The remote will not allow me to change channels
    Scholar:
  • 89 Answers
Hey!
You want to make sure the buttons are customized, the following link shows how this is done:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9700
If it is still not working, you might want to learn the command:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9603
Hope these help your problem!
-Kennedy
Posted on Apr 02, 2010
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
How do you get your tv to channel 3 without remote
It Depends on the model but most tv's have a manual button on them that allow you to change channels. If that still doesn't work you may need to do a channel search and then change it to channel three. I will need to know the make/model of your TV to help further.
Apr 07, 2013 | Coby TF-TV3217 32 in. LCD TV
TV is on one channel and will not work with remote or allow me to change channells from side of tv
I've run into this same issue. Although not a complete fix, I was able to program the tv with a basic universal remote. Try using the Goldstar remote codes. While I'm unable to use the channel buttons, I can change channels manually and turn the tv on/off and use the volume button. Again, not a fix, but a work around for now.
Jun 25, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Can't get the channel to change so that the cable works, it's stuck on Channel 4 and needs to be Channel 3
i take it you dont have a remote and your control panel is not working the best fix for this is to go and purchase a cheap universal remote control and program it to your tv this will allow you to change channels
Jan 02, 2011 | Toshiba MD20FL1 20 in. TV/DVD Combo
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Can not change channel with my new remote on my bell receiver
There could be a few different things causing the problem, but beginning troubleshooting would consist of the basic questions such as, are there fresh batteries in the remote and is the remote in the correct "Mode?" In order to change the satellite channels- remote needs to be in "SAT," mode, you can verify what mode the remote is in by attempting to change channels, or by simply pressing any button on the remote such as channel up or down - if the remote is in fact in sat mode the "SAT" button in the upper left hand corner of the remote will light up- this will allow you to confirm the remote is in the correct mode to allow you to successfully change channels. Also another potential issue is when you started experiencing these remote problems- has anything changed? Did you perhaps move the receiver to a different/new location? The sensor on the top of the remote and the front panel of the receiver need to have a clear path of signal in order to work, sometimes (usually rare) if the receiver is enclosed within a cabinet with glass doors this can cause an issue as well. Hope one of these tips helps; feel free to contact me directly if you need any further assistance.
-Kirstie DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
My remote won't allow me to turn on our TV but after I turn the TV on, the remote allows me to change the volume and mute but will not allow me to change channels.
I would re-program the remote. I don't belive this is the exact correct code. Some codes kinda work but no fully. That's when it's time for another code for your brand or use the setup and power auto-code search
Apr 08, 2010 | Philips Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
We have a Dynex 32" flat panel. When we change channels sometimes, it will suddenly stay at a channel and won't allow you to change channels or change the volume for a couple of minutes. Not sure if it's...
I'm not sure why this works, but remove a battery from the remote, (I'm assuming, here, that you're using the remote...) wait ten seconds, and replace the battery. (just one will do...)
Aug 05, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I lost the original remote to my 27'' television
very sorry for that but you can be changing channel manually on the tv channel buttons, if you sweep on all channels you can go to AV from RF channels, that is before you buy a remote.
try to buy your remote from
www.ebay.com
Apr 28, 2009 | Televison & Video
Logitech Harmony 890 LCD Remote Control Logo
54 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
