How can i reduce the size of the picture on my Colby TV.
The picture is too large left to right
    Top Expert:
  • Televison & ... Master
  • 28,920 Answers
Yes, look for Settings - Picture - Aspect Ratio
https://www.rtings.com/tv/learn/what-is-the-aspect-ratio-4-3-16-9-21-9
You can also google
make model manual
Posted on Aug 22, 2019
SOURCE:
Tech4lfe
  • 42 Answers
SOURCE: Picture too large for screen size
It's usually called format if it is an RCA
Posted on Mar 06, 2009
  • 52 Answers
SOURCE: text msg font size suddenly extra large, how to reduce size
use the volume key and act like your turning the volume down and the text size will go down.
Posted on Jan 31, 2010
  • 11800 Answers
SOURCE: Comcast picture won't fit in
What you see is called overscan - full explanation here
http://en.wikipedia.org/wiki/Overscan
On your tv it can be removed only when the tv is in PC mode, with the signal coming thru the VGA connector.
Posted on Sep 22, 2010
SOURCE: tv picture is getting too
Hi, well this is most likely a Aspect Ratio issue, this can be set via the TV's Menu. You simply need to adjust this aspect ratio, to suit you viewing requirements.
It is all explained how to do this in your user manual, link provided below. http://www.devicemanuals.com/guide/Television/Symphonic/Symphonic-ST420FF-20-TV-Owner's-Manual-T0RVek16az.html
Posted on Sep 29, 2010
SOURCE: 55 inch vizio tv has large image and cannot get the right size
HI!!!!!!
Posted on Mar 03, 2012
I need to reduce the size of the picture on my vizio tv screen. The technician made it so large the whole picture is not shown
From the Vizio remote in the menu, find the picture settings and select the size you prefer.
Jan 02, 2018 | Vizio Televison & Video
How do I reduce scan file size when the resolution is already 200 dpi?
An 8.5 inch wide document scanned at 200 dpi gives you an image that is 1700 pixels wide. This is almost enough to fill a fullHD TV screen at native resolution (1920 pixels wide) which is unnecessary detail. I would use any picture editing programme (many free ones available) to reduce the overall pixel width of your already scanned images by 50 percent. This will automatically reduce the 1MB image to 250k. If you can scan again, use 100 dpi to scan - the result is same; image will be half as wide (and long), and picture file size one quarter of the 200 dpi scan.
Sep 12, 2017 | Samsung CLX6220FX AllInOne Laser Printer
Picture size is to large
You might have it in the wrong picture size (zoom 1 or 2). Menu, picture, size ...
If this is not the case, you can go to the service menu and reduce the size of the viewing image.
Turn off TV, press mute then 182, Turn on TV and this menu appears.
Jan 17, 2013 | Samsung HLT5076SX
32C3500E Toshiba - I want to reduce the size of the picture it is now too large for the 32 inch screen which buttons do I press to reduce the size please
RIGHT CLICK YOUR MOUSE ON YOUR DESKTOP...SELECT CUSTOMIZE MY DESKTOP...ON SCREEN DISPLAY...SELECT A SMALLER SIZE.
HOPE THIS HELP!
Aug 31, 2011 | Computers & Internet
Need to reduce size of picture on screen Is there a way to do this
Yes there is a way to reduce a picture size. when you open your tv on the right of your card, there is a line transformer with so many inputs. the input you are using has much current- reduce the current on the put of your tv line transformer.
Dec 31, 2009 | Televison & Video
Picture fluctuates in size
its possibly some connections in the horizontal output circuit or a capacitor failing causing this
if you have some tools soldering station ect and a little know how you can most likely handle this problem
Oct 27, 2009 | RCA D52W23 52" HDTV CRT TV
Image too large for the screen
you need to replace filter capacitor from vertical section area and horizontal section area. i already encounter tha kind of problem and fix replacing vertical section capacitor.
Apr 19, 2009 | Sony KV-13M42 13" TV
Ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Feb 26, 2008 | Televison & Video
Taking a smaller image from S80
In picture-taking mode, hit the Func Set button. You will see menus of options along the left side and bottom of the display. Tap the bottom of the scroll ring (the ring around the Func Set button) until the bottom option of the left menu is highlighted in red. This option sets the image size of the pictures you are taking. Change this size by rotating the scroll wheel. The 5 options are Large, Medium1, Medium2, Medium3, and Small. The image size in pixels is displayed above the bottom menu as you switch between sizes. When finished, hit Func Set again.
Jun 25, 2007 | Canon PowerShot S80 Digital Camera
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Ekse
