Question about Beko Refrigerators
My Beko FFG1545S fridge freezer's red exclamation warning light has appeared What does this mean
3 Suggested Answers
SOURCE:
gopakumarg43
  • 76115 Answers
SOURCE: Hi. I have a beko American style fridge freezer, the exclamation mark in a red triangle has suddenly appeared, what does this mean?
The fridge has been found some strange things inside.
Posted on Mar 25, 2016
  • 6004 Answers
SOURCE: My fridge freezer red exclamation warning light has appeared on the temperature panel it has never happened before help ! What does this mean I have a Beko AB 910S
The red exclamation mark means that the freezer is too warm to keep items frozen. Make sure that the freezer door is closed. If the freezer is opened frequently, reduce the number of times that the door is opened. If you put in a lot of fresh food, you may have to wait for the freezer to chill.
If the problem persists, then you need to check if the fan is running properly. Replace it if needed. Otherwise, the freezer sensor may be faulty.
The manual for the AB910 is available online. One source is at Manuals Lib: https://www.manualslib.com/manual/15132/Beko-Ab910.html . Beko has some of the parts here: https://www.bekospares.co.uk/fridge-freezer/ab910s-7218846385/catalogue.pl?path=110911&model_ref=11336069 . Other sources will probably also have the parts.
I hope this helps.
Posted on Apr 26, 2018
I hope this helps.
Apr 26, 2018 | Beko Refrigerators
Beko fridge freezer I have square red sympol with an exclamation mark flashing
consult manual for trouble shooting or contact support through manufacturer website
Jul 23, 2016 | Beko Refrigerators
I have a beko fridge freezer seral no0810452709 model cda554w is this one of the models recalled
The model number you have supplied doesn't appear to be in the correct format. Please see the information that follows.
I'm pasting this response on all queries regarding the recently announced issue with BEKO fridge freezers and the risk of fire from their defrost mechanisms, but I have placed it here in hints and tips too, in the hope it will be of use to any concerned BEKO Fridge owners:
According to several sources I have checked, including the London METRO magazine ( http://www.metro.co.uk/news/868330-beko-fridge-freezers-fire-risk-warning-issued-to-homeowners-amid-recall) The MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
From what Ican ascertain, the fridges affected were manufactured between January 2000 andOctober 2006 (So, after shipping and sitting around in shops, you can probablyextend that margin to machines SOLD between 2000 and 2008)
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
I have to say. Regardless of dates and matching serialnumbers, if I had an affected model,I would be checking with BEKO anyway!
Jul 05, 2011 | Refrigerators
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 | Freezers
Flashing light re temperature in fridge jenn air model
Your freezer may be a fan cooled system. Make sure that nothing is crammed up against the fan grill as this stops the air flow and probably causes the red light warning
Mar 28, 2010 | Refrigerators
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Fridge problem
means the temperature has gone up and freezer temperature is too high. fault should rectify itself given some time
May 11, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
29 people viewed this question
Top Beko Refrigerators Experts
gbob59
Marvin
Marvin
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
