Question about Panasonic Televison & Video
MY TV PANASONIC SERIAL # PT-50-LC-14 IS HAVING A PROBLEM WHEN I TURN THE TV ON THE POWER BOTTOM START FLASHING ON GREEN THAN IT TURNS TO YELLOW FLASHING ,THAN RED FLASHING AND THAN IT TURNS OFF.THE SCREEN STAYS DARK UNABLE TO SEE ANYTHING THE PROJECTOR LAMP WAS CHANGE TO A NEW ONE AND THE TV STILL NOT WORKING AND IS DOING THE SAME FLASHING PROBLEM THE SCREEN STAYS DARK LIKE IF IT WAS OFF AND IT DOES'NT MAKE ANY NOISE
  • lopez2322 Sep 13, 2009
    where is the board loccated what can i do to fixed
    President:
  • Panasonic Master
  • 1,922 Answers
The problem is most on the horizontal and vertical deflection circuit board,it uses a switching type power supply and this is the reason the l.e.d.s are changing colors upon powering up,it is doing a self start test of the entire set and you have a problem in that area and it wont power-up to save set from more damage from a possible shorted/defective component on that board.
Posted on Sep 13, 2009
  • daniel  hendrickson
    daniel hendrickson Sep 13, 2009
    the boards are marked def. for deflection,there should be a pictoral diagram locator somewhere inside the set and will show you the boards location
TV will not turn on-- clicking noise in the back
The power pack the the power cord goes into has gone bad and needs replaced, see manufacturer for service or parts.
Nov 15, 2007 | Panasonic PT-50LC13 50" Rear Projection...
I've replaced the lamp for my panasonic 50DL54J. When i try to turn the tv on, the power button blinks green, then turns yellow, then the lamp red light blinks..and turns off. Can you please help?
some times when the lamp is not sitting in place it will give you this problem. removed the lamp, put it back and make sure it goes all the way in. close the door and attach screws if any. remember if the lamp door is not close, your tv will not turn on. had the same problem until i reseted the lamp in place. good luck
May 13, 2011 | Panasonic PT-50DL54 50" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
I turn TV on and green light flashes for a few minutes then turns off and I get a red light flashing twice about every 5 seconds
Power Supply board is dead.Replaced the power supply board will solved this.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 15, 2010 | Panasonic PT-50LCZ70 50" HDTV
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
My panasonic pt-61lcz7 HDTV
Was it because the light bulb burned out on the back projection TV? I'm having same issue now. Did you solve the problem?
Jul 04, 2009 | Panasonic Televison & Video
Panasonic TV
Good Day,christie511;
It sounds like the lamp is in need of replacement. You could call a service company to replace the lamp, but it is so easy to replace the lamp ones self. So, call Panasonic and order the lamp, they will send to your home with instructions.
Three screws and your home free!
Good Luck, Big Irish.
Jul 08, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
