Question about Sharp Microwave Ovens
Sharp microwave. code AC-1 microwave, stops and displays this code
    Sergeant:
  • 293 Answers
Try unplugging uni t for 10 seconds,then plug back in. If that doesn't work, contact a technician. For service.
Posted on Aug 28, 2019
3 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Microwave error code
EE4 means the line voltage is too high. Usually this is fixed by resetting the voltage selector on the back.
The voltage selector may not look like a switch, looking rather like a metal panel that has to be taken off and reoriented. There will be a label next to it indicating a voltage number.
EE2 actually means that the control circuit senses that magnetron number 2 is not running.
It doesn't necessarily mean a bad magnetron.
This can be due to a bad or misaligned door switch (common), a failed relay (#3) on the control panel, or a failed high voltage component such as transformer #2, capacitor #2, rectifier #2 or magnetron #2 or loose connections anywhere along the chain.
We have a similar model's service manual on our site. Please not that yours may be different! Part numbers will probably not match. But it will help with safety, disassembly, discharge and diagnosis.
It's here: http://www.microwavedisplay.com/r23gtf_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Posted on Sep 29, 2008
Microwave is in Lock -- how do I unlock it?
" 1. CHILD LOCK
The Child Lock prevents unwanted oven operation
such as by small children. The oven can be set so
that the control panel is deactivated or locked. To
set, touch Custom Help, the number 1 and Start/
Touch On. Should a pad be touched, LOCK .
.. ON will appear in the display.
To cancel, touch Custom Help and Stop/Clear. "
Also, to find manuals........
Oct 03, 2014 | Sharp R-1480 Microwave Oven
Code ee 5 on sharp microwave model rcd 2200m
It may be that the voltage selector on the back of the oven is not set to the proper level of your AC supply.
It will probably have settings for 208VAC or 230VAC.
Chances are your oven is set to 208VAC but it is on a 230VAC line.
Refer to your owner's manual for specific details.
Jan 15, 2013 | Sharp RCD2200M Microwave Oven
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
Sharp Microwave on "Lock" and
The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
Mar 08, 2011 | Microwave Ovens
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Jan 06, 2009 | Sharp R-308J Microwave Oven
Sep 28, 2008 | Microwave Ovens
Sharp R-1502
there are 2 fuses inmicrowave 1 for ac input 1 for high voltage transformer that will trigger the magnetron "for heating"
remedy;
uncrew the unit
replace fuse near the transformer this fuse.. usually enclose with plastic casing..
then test..
causes of blown fuse
improper ventilation
Feb 20, 2008 | Sharp R-1502 Microwave Oven
Sharp R-1441
There should be a "CUSTOM HELP" or "HELP" pad on the keypad. When you press that, "CHILD LOCK" should be the first option. The display will guide you to press 1 or 2, etc., to turn it off. We don't have an online copy of that manual, but it's part number TINSEB114MRR0 (zero on the end). You can order it via Tritronics at http:/www.wehaveparts.com
Oct 04, 2006 | Sharp R-1871 Convection Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
