Question about Balboa Instruments Duplex Digital Panel 2 Pump
New (used) hot tub filled with water now it wont stop running
My hot tub wont stop running, it also wont let me turn it off manually,temp went up to 107 (heater element?)help
I replaced the upper control panel, and that was the problem.
Posted on Sep 14, 2009
    Problem Solver:
  • 13 Answers
Check your filtration cycle, see if it has been set for Fil 8 or Fil C. this is normally the main fault I see when I visit spa's that are overheating and not shutting off.
would not be the heater but the heat from the pump where it is running all the time, generates it's own heat (a pump can generate up to 26 degrees temp on it's own if run long enough)
if still continues then maybe a circuit board fault
thanks Adam Miller
service manager, Canadian Spa Company, UK
Posted on Aug 12, 2010
54075 hot tub heater keeps stopping
check filters if ok check pressure switch if ok check temp sensor if ok check to see if heater element is ok
Apr 17, 2014 | Pool & Spa
Catalina spam
Hi, Lori Thanks for the question. It sounds as though your tub froze over and tripped the freeze sensor. If the freeze caution is gone and the tub will not rise to temp, either 1 of the heat sensors or heating element has gone bad. With a bad element or sensor you should have an error code on your topside display. At this point I would recommend contacting a Spa Technician, unless you have some spa repair knowledge or feel comfortable attempting a self repair. I hope I was able to help, Thanks again!
Feb 12, 2014 | Pool & Spa
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
240 w/60 a outside breaker with test switch wont'
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Sep 28, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
Heater not coming on.
sounds like the heater element is out. if you turn the breaker on and once the tub cycles on it trips the breaker again. it is definitely the heater element.
Jan 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Balboa Instruments Duplex Digital Panel 2 Pump Logo
1,210 people viewed this question
Top Balboa Instruments Garden Experts
Craig Butler
Craig Butler
Delage guy
Delage guy
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
