Question about Cell Phones
Ringer will not work - Cell Phones
How to Ringer On of Panasonic KX-MB772
Before adjusting volume, set the operation mode to fax
mode (page 16).
Ringer volume
While the unit is idle, press {V} or {^}.
L If there are any documents in the document
entrance, you cannot adjust the volume. Confirm that
there are no documents in the entrance.
To turn the ringer OFF
Press {V} repeatedly to display "RINGER OFF= OK?".
i {SET}
L The unit will not ring.
L To turn the ringer back ON, press {^}.
Ringer pattern
L You can select one of 3 ringer patterns (feature #161
on page 50).
Monitor volume
While using the monitor, press {V} or {^}.
and if it work then say a thanks to your Pakistani Brother.
Dec 10, 2013 | Panasonic Office Equipment & Supplies
Samsung GT-E1081t ringer solution jumpers
Jul 04, 2012 | Cell Phones
Hi anna i have a problem it is ringer is not working
Hi there
Go to menu,phone settings,ringer settings to check if your ringer is on or off,if it is off switch it on
If your ringer still isnt working then you should have your ringer changed.An expert or anyone with experience should be able to do that.
Oct 02, 2010 | Nokia 1600 Cellular Phone
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 | Cell Phones
One of my phone reads "ringer off" and I want it "on"
hello,
i believe have ringer on and ringer off.
press the menu, press the profile, then, choose a profile, personalize it.
when personalizing you will see ringer on and ringer off change it to ringer on and activate the profile. i am your phone will ring.
thanks for using our website
Jun 05, 2010 | Uniden DECT 6.0 Cordless Telephone...
The ringer no longer works on my Nokia 6585. Is it
There are no parts. per'ce, for this. the ringer function is electronic. Make sure you dont have the ringer turned down or off.
Dec 07, 2009 | Nokia 6585
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
China mobile ringer problem
sigmatel s890 ringer not working pls give me a solution immedietly
Sep 16, 2008 | Handmark Software MobileLists (950142) for...
Ringer and picture Id
The first thing you have to do is go into the settings and tools menu. Once there got to option 6, call settings then ringer ID make sure it's set to on and then do the same for picture ID. That should take care of the problem. Hope that helps!
Mar 02, 2008 | LG enV VX9900 Cellular Phone
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
Settings > Ring Styles > style Detail
> Ringer IDs > On
Dec 13, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
