Question about Cameras
MY BELL & HOWELL 8 MM DOUBLE FEATURE PROJECTOR WILL NOT FEED FILM
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 30 Answers
If you can hear the motor running then it is most likely the belt that connects the motor to the takeup is broken or stretched out and not longer driving the reel. That is a pretty easy repair.
If you cannot hear the motor then the trouble is more serious and probably not worth repair.
Posted on Sep 11, 2019
SOURCE:
SOURCE: How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Posted on Mar 17, 2009
SOURCE: Movie film wont feed
junk it
Posted on Mar 22, 2009
  • 685 Answers
SOURCE: film is not being drawn into the gears
Check the drive belt, if the belt is too loose it will not pull the film inbeasuse ther is not enough tension on the pulleys and the belt will slip. If you need the belt, good luck finding it as there are nearly impossible to find.
Posted on Nov 04, 2009
  • 82 Answers
SOURCE: I NEED A OPERATORS MANUAL
Hi There, try the link below they have hundreds of manuals for Bell and Howell Cine Cameras.
http://www.ephotozine.com/equipment/manuals/bell-and-howell/10/Cine-Camera/4
Good Luck
lacala69
Posted on Apr 24, 2011
kerguney
  • 577 Answers
SOURCE: I have a Bell &
Hi
most of the projectors handle 2 different versions of 8 mm films.. and ..
in accordance with this feature again most of the projectors have a switch that can run either of the version..So,your projector should have a switch to handle either of the standards.8 mm film is slower than super 8 ..You must have recorded super 8mm and now triying to play on 8 mm..If I knew your movie camera model I can tell the which one is.As far as I have checked your projector can only hande and not capable
Sorry about it.you must find another projector that can run your super 8 mm..just in case if you need a user manual pls visit the link below..
Hope this helps..if not pls ask me more..
Regards
Bell & Howell 253 & 253AR Movie Projector Manual
http://www.ebay.ca/itm/Bell-Howell-253-253AR-Movie-Projector-Manual-COPY-/250654001790?pt=US_Movie_Slide_Projectors&hash=item3a5c248a7e
Vintage Bell & Howell 253 AX 8mm Movie Projector
Circa: 1950's
Condition: Used & Operational
Size: See Description
Color: Brown-Gray Wrinkle Finish
Country of Origin: United States
Manufacturer: Bell & Howell
This great machine has a metal plate that says: 115 V. AC 60 Cycle Only 500 W Max, amps, Chicago 45, ILL, U.S.A. Projector Model 253 AX Bell & Howell. It has the Frame lever and a switch that has Lamp, Motor and Off. It works great. A metal take up movie reel comes with the projector. The unit is compact and has the metal lid with a pushbutton that opens the projector when depressed. There is a switch on the side that has the Rewind and Forward.
It measures approximately 12 inches tall by 8.5 inches wide and 8.5 inches deep. It is a heavy, well built projector and is the Iron Horse of the 8mm movie projectors of the 1950's. This projector works great and it has been serviced and ready for you to watch your old home movies.
Posted on Aug 05, 2011
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
Manual for bell & howell 2143 xl 8mm film camera
The Bell & Howell 2143 XL manual is not available for free online. However, a few sites have reprints or original copies for sale. One source: http://www.oldtimercameras.com/manuals/camera-manual-Bell-and-Howell-2143-1075.asp . There is also a repair manual available. The instruction manual is under $15 plus $8 postage.
I hope this helps.
Jul 19, 2016 | Cameras
I need a replacement "Feed Belt" (like a long spring) for a Bell and Howell Filmosound 302 16mm projector circa 1950
Larry Urbanski at Urbanski Film in Illinois stocks the spring belts for all brands of 16mm projectors.
Oct 17, 2013 | Bell & Howell Bell Howell Filmosound Movie...
I NEED A OPERATORS MANUAL FOR A BELL & HOWELL 8MM FILM PROJECTOE MODEL 487A
Good Luck
lacala69
Apr 23, 2011 | Computers & Internet
Bell+Howell FILMO 8mm Projector
If the backside of the arm opposite the the pin holding the reel has a screw [possibly plastic] loosen it 1/2 turn at a time. First put a film reel on the pin to check each adjustment buy putting the empty reel with your finger.
Nov 30, 2009 | Bell & Howell Photography
Sam
Feb 23, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Cameras Logo
20 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
