Question about Cameras
I have sv3c hx series camera i caint find where to put the sd card slot
SOURCE:
Dipu007
  • 2110 Answers
SOURCE: Fujitsu N3511 not reading 2GB SD Card
you have install memory card driver first..
Posted on Dec 08, 2008
Meganerd X
  • 117 Answers
SOURCE: I put my wii powersaves card into sd slot but they wont load
To use a wii powersave, you need to follow these easy steps.
1 Go on to the Wii oprion menue.
2 Go into the data management section.
3 Click save data
4 Click on Wii.
5 Click on SD card.
6 Search for your game title.
7 Click on it.
8 Copy the game data to your Wii.
Hope it helped!
Posted on Dec 30, 2008
  • 207 Answers
SOURCE: sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Posted on Apr 21, 2009
pshinde23
  • 136 Answers
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Posted on Jun 25, 2009
Geekman
  • 32281 Answers
SOURCE: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Posted on Aug 14, 2009
Can you put micro sd card in camera n13275
Is this information not contained within the camera manual ? If it has a micro-sd slot, then there should be no trouble; if the slot is for a full size SD card, then you will need an adapter.
Jul 19, 2016 | Cameras
Hp back files on card can my computer restore these
The Hx 4700 series and the & The Hx2190 have a removable card Compact Flash or SD Card, if the information you want was stored on these you can buy a USB Card reader from woolies plug the SD or Compact flash into the card reader and plug it into the USB port of your PC or mac and it will be readable (no drivers needed). You may also be interested to know that there are updated ROMS available for this model to update the OS & the Office Apps + increase the max capacity of the storage cards that are recognized.
Mar 29, 2014 | HP iPAQ HX4700 Pocket PC
Says sd card error
Are you sure it's an SD card? Even though SDHC cards will also fit into the slot, they will not work in the A540. If the card is larger than 2GB then it will not work.
Feb 03, 2013 | Canon PowerShot A540 Digital Camera
Check sd card
The V800 works with SD cards. Your new 16GB card is a SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to go with SD cards, 2GB and smaller.
Feb 23, 2012 | Samsung Digimax V800 Digital Camera
When i put my sd memory card back in my digital camera it said file error
This can be due to a corrupt configuration file in the SD card. I recommend:
1) Insert the card in the SD slot in a computer that has the slot
2) Go to "My Computer" (or "Computer" in Windows 7)
3) Right click the "SD card" icon
4)Click "Format..."
5) Press "Start"
Then you should be able to use the SD card properly with your camera.
Apr 05, 2011 | Cameras
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
The SD slot on my digital camera looks wider than an SD card
It appears to be a normal SD card slot.
The camera can handle cards up to 1GB.
Dec 07, 2009 | Cameras
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Toshiba won't read my SD Card
Reinstall your 'flash media' drivers (usually available from manufacturers website). It worked on my satellite p200 series running vista home premium 32.
Dec 25, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Cameras Logo
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
