Question about Craig Audio Players & Recorders
I have an old Craig Clock Radio, model #CCR-41450. Recently when I turn the radio off the clock won't keep the time, it resets to 12:00 and flashes when I turn the radio back on.
SOURCE:
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Posted on Jul 27, 2009
  • 136 Answers
SOURCE: setting clock on pioneer radio
you will need to turn unit off then press function button for a few seconds this will take you to the clock function.
Posted on Sep 05, 2009
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
  • 5 Answers
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Posted on Feb 21, 2010
Please wait keeps flashing on the screen and the clock loses time
OEM radio issues. Flashing Time. Radio Not Working... - Drive ...
www.driveaccord.net/.../51717-oem-radio-issues-flashing-time-radio-not...
Sep 20, 2010 - When I reconnected the battery, the radio does not work anymore. ... I reconnected it, turned the key and the clock is still flashing. ... Wait about three minutes or so, and reinstall the fuse. .... Please let us know what it was. .... Naviscreen comes up but I can't do anything with it because the buttons are dead.
Novelty Simpson Jukebox Alarm Clock Radio Homer ... - Fixya
www.fixya.com/search/p94498-novelty...clock/welcome_please_wait
Novelty Simpson Jukebox Alarm Clock Radio Homer Simpson Animated Jukebox Alarm ... ...welcome Please Wait" Every time I try to use any handset the screendisplays ... This keeps flashing for several minutes, and never seems to resolve.
Troubleshooting - Shop - SiriusXM Radio
Jan 16, 2016 | Audio Players & Recorders
Tip
How to set time
Hold stop/Adj until clock flashes, then press H/M to adjust
on Nov 19, 2013 | Craig Dual Alarm Clock Radio With CD...
My G.E. clock radio (model 7-4616B) has a feature that allows me to reset the time if the power goes off by pressing forward, or fast forward, or reverse. Recently, we lost power. The radio...
perhaps you need to buy a can of electronic contact cleaner and use some on the buttons .Just last night I had to do this with our bedroom clock radio to go back 1 hour
Oct 30, 2017 | GE Audio Players & Recorders
Since the time change I can't reset my clock. It
If your clock radio is more than two years years old it will be operating on the old changeover schedule, and there's no way that you can change the schedule. What you can do though, is turn the DST switch (if so equipped) to the OFF position and change the time manually. If yours is an "atomic" clock you can force the change by setting the clock to a different time zone. (I have an atomic clock that's set up on the old schedule. DST is OFF, and I change the zone between the Central and Eastern time zones.)
Bill B
Apr 02, 2010 | Emerson SmartSet CKS1850 Clock Radio
Troublshooting my clock radio CKW2000 Emerson Research All Alert Clock Radio
I don't know if it work for everybody, but, I took out three of the batteries, then unplugged the radio and plugged it back in. That just left the bottom light blinking, I then pressed the power button on and back off. I had to reset time and date, but it got rid of the flashing lights.
Aug 30, 2008 | Emerson CKW2000 Clock Radio
Smart set radio cks 1851. It will not keep the time and now blacks out. New battery installed. Folled plan of reset. lasted approx 10 minutes and blacked back out. Was plugged into electric at the...
Sorry it took so long to get back to you with a solution to your problem. You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Jul 19, 2008 | Emerson Smartset Clock Radio
Sony Liv Clock Radio, Cd Player
I have a sony dream machine ICF-C18 and had day light saving time and cannot change the time
Please help
Jun 17, 2008 | Sony Dual-Alarm AM/FM Clock Radio with...
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Top Craig Audio Players & Recorders Experts
MsIslander
Level 1 Expert
Ekse
 Grubhead
Grubhead
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
