Question about Mtd 22" Yard Machine Push Mower
Yard Machine won't start
When pull the cord for mower to start it woun't
    New Friend:
  • 93 Answers
Maybe the Spring is broken in the housing, that is assuming you are talking about a problem with the pull cord. Your question is kinda vaque. Submit more information !
Posted on Sep 15, 2009
Repair lawn mower pull cord
Home Depot sells a replacement pull cord kit that has great instructions. My mower, however, had pop rivets holding the cover on the engine, so if yours does too, get a pop rivet tool with the correct size pop rivets before you start drilling out the old pop rivets.
Aug 07, 2014 | Mtd 22" Yard Machine Push Mower
I have a yard machine 123cc 21"! It will start but
It\'s the carbrettor. Not enough pull to suck fuel.
Jul 04, 2013 | Garden
I borrowed my Brothers Tecumseh Yard Machine Push Mower to mow my lawn but the pull cord wont pull. Is there a saftey or something i dont know about ?
There is a little bar up by the handle that you have to pull back toward the handle, this is the dead man lever. When released it will stop the mower by grounding out the ignition coil and braking the engine.
If this is not the problem, then let me know.
I hope this helps.
Aug 09, 2011 | Mtd 22" Yard Machine Push Mower
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
22" Yard Machine Push Mower: how long should i make my pull cord when i replace...
long enough that when you pull it you don't hit feel it come to the end of the rope. Short enough that it winds all the way up.
When I replace these things I use a little more than an arms length. 3 foot or so. I wind the spring till it is tight then slide a screw driver through the top to hold the wheel so I can thread the cord and knot it. Then I let it wind itself up until it stops and then add handle and pull just enough tension on it to tie the knot in the handle and make sure it pulls the handle snug to the housing.
May 17, 2010 | Mtd 22" Yard Machine Push Mower
Yard machine mower start and quits
this sounds like faulty switch or more likely a break in the cord close to the where the the extension cord exits the machine.
Jan 28, 2010 | Mtd 22" Yard Machine Push Mower
I need to replace the pull cord on a 4hp, yard machine, 21",mower
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 20, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Jun 08, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
328 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
