Question about Radio Communications
How to delete old users paired to my Bluetooth sync on my ford explorer 2014
SOURCE:
SOURCE: plantronics explorer 220 bluetooth
I have a Samsung t 509, and a Plantronics 220. When set it up it connected fine. It wil not connect anymore. Need a lil help
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: Lost my phone Got a new phone, cant reset bluetooth
the pass key is 0000
Posted on Mar 01, 2009
SOURCE: Bluetooth pairing
hi turn parrot on and press red and green buttons together parrot should say erasing memory.
Posted on Jul 26, 2009
  • 15 Answers
SOURCE: g2 bluetooth will not sync with any other phone?
first u check whether..that model will support to your mobile..
Posted on Aug 13, 2009
tjtampus
SOURCE: I am having a hard time pairing my Bluetooth to my
hi karen dis is joahna nerry tampus i want to get dis cellphone..
manny people sending me a free cell phone in friendster..
i want to get dis..
my address is 2795 luzviminda st. timog caa laspinas city..
and im joahna nerry tampus.. i hope i get dis cell phone.. thnak you...
Posted on Aug 19, 2009
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Can't sync my plantronics explorer 240 to my i phone
Here are some things to try. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. The attached user guide for the Plantronics Explorer 230 (240) on page 7 will show you how to turn off / on the headset (to reset headset) and then page 4 will walk you through the pairing process. Remember to remove any lingering bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Dec 02, 2011 | Plantronics Explorer 240 Bluetooth Headset
I am unable to pair my Nokia N96 with Plantronics Explorer 240 / 395 bluetooth headset.
If you see your Bluetooth listed on your phone: delete it then turn your Bluetooth off. Turn off your phone and take the battery out of your phone for a few moments, reinstall the batter and turn your phone back on. Turn your Bluetooth back on and try repairing them again.
Here is a link to the Plantronics Explorer User's Guide.
Aug 30, 2011 | Plantronics Explorer 340 Wireless Headset
Even though the volume is turned all the way up on both my cell phone and on my plantronics 220,both fully charged,I can barely hear any type of call. whether its a given or recieved call.
Try to delete the bluetooth from the phone, and re-pair it or subscribe back on the phone. It may be that your headset is old and needs to be replaced. If this does not work look at the Plantronics M100 bluetooth headset.
I have included the users guide for the Plantronics Explorer 220 headset.
Jul 18, 2011 | Plantronics Explorer 220 Bluetooth Headset...
CAN I CONNECT A THIS TO A LAPTOP? IF I CAN HOW?
You can use the Plantronics Explorer 240 on your computer if your computer has Bluetooth built in. Just turn on the Bluetooth feature in the computer and pair up the headset. You can get a USB Bluetooth adapter if your pc doesn't have Bluetooth built in, then just pair the headset to the adapter. Here is a link for the 230 / 240 user guide, it will have the pairing instructions for the Explorer 240.
Mar 17, 2011 | Plantronics Explorer 240 Bluetooth Headset
My bb 8310 AT&T device won't pair with a headset or with my ford fusion
Make sure you have the correct password for your phone. Also look in your fusion manual as to the correct steps needed.
  • Press the Power Button. // This is on a 2010 Ford Fusion.
  • Then you hit the Phone Button.
  • It should say “No Phone Paired” that means that no phone has been paired with this.
You now have a choice of options:
  1. Add Bluetooth device
  2. Connect Bluetooth device
  3. Set Primary Phone
  4. Set Bluetooth On/Off
  5. Delete Device
  6. Delete all Devices
You want to choose Add Bluetooth Device, press OK
  • Then on your mobile, turn your Bluetooth On.
  • Setup Bluetooth – Search
  • Now it’s searching for it, when that gets full, Click Sync.
  • Then you’ll want to enter the PIN number that’s on the screen.
  • Say YES to connect to Sync.
  • Now screen on dash will say your mobile phone
Mar 26, 2010 | RIM BlackBerry Curve 8310 Smartphone
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Feb 14, 2009 | Plantronics Explorer 330 Headset
Radio Communications Logo
16 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
