Tv & video: Which cables join to where
What combination of cables do I use to connect my dvd-vcr to my lcd tv (both Samsung), and which ports do I use?
  • 244 Answers
You need to put the main aerial into the vcr,then a male to female fly lead from the vcr into the tv and then a scart lead from av1 on the vcr into the scart socket on your tv.
Posted on Sep 17, 2009
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
LCD TV connection to DVD-VCR
OK here is a possible solution: 1) The best solution: Connect the antenna to your DVD-VCR through the RF Input and the the RF Out to your TV This take care of the VCR part. Then you get an RCA three way cable (Video-yellow marked, Right Audio-Red marked, Left Audio-white marked)connect the yellow marked RCA cord to the Video out of your DVD player then connect the other end to your video in of your TV. Ater that connect the red marked audio cable to the R Audio out of your DVD player to the R Audio in of your TV do the same for the white marked Audio cable. You will now be able to switch from VCR-RF to DVD-RCA.
Sep 11, 2007 | Televison & Video
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Can't record from tv
u have a cable/sateliite connection...cable from wall to cable box in...cable box out to vcr/dvd in....vcr/dvd out to samsung lcd in....(vcd/dvd and samsung must be tune to ch 3) now u should be able to record all channel (note HBO, and some others like it may not allow dvd recording) vhs yes.
if this helpful feel free to rate
Jun 16, 2009 | Sylvania DV220SL8 DVD Player/VCR
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
