Question about Dell Computers & Internet
Horizontal and vertical do not scroll how do i enable
  • 28 Answers
You can open the Dell touchpad settings by opening the program located here:
C:\Program Files\DellTPad\DellTPad.exe
or open via control panel by going here:
Control Panel -> Hardware and Sound -> Mouse and click on the image under 'Dell Touchpad'
Hope that helps,
Tiger720
Posted on Sep 13, 2009
How do I unlock the scroll lock on a Compaq laptop please?
To enable horizontal and vertical scrolling on your Compaq laptop, you can follow the instructions mentioned on the link below:
http://www.ehow.com/how_8708935_turn-scroll-compaq-laptop.html
GuruAid.com
Apr 09, 2015 | Compaq Computers & Internet
Gateway NV52L06u how do you turn scroll lock off?
Device settings > Synaptics touchpad > settings > virtual scrolling > untick the "enable vertical scrolling" box.
The "enable horizontal scrolling box should be there too.
Apr 20, 2013 | Gateway NV52L06u A6-4400M 2.7GHz 4GB 500GB...
How to scroll with touchpad on hp g72
Go to:
Control Panel -> Mouse
click there ' Device Settings ' tab. Choose ' Synaptics TouchPad ' and little lower click on ' Settings... '. From the list which will be there select ' Scrolling ' -> ' One - Finger Scrolling ' and uncheck (if they are checked):
  • Enable vertical scrolling
  • Enable horizontal scrolling.
Click ' OK' .
original?v=mpbl-1&px=-1
Next go to:
click there ' Device Settings ' tab. Choose ' Synaptics TouchPad ' and little lower click on ' Settings... '. From the list which will be there select ' Scrolling ' -> ' Two - Finger Scrolling ' and uncheck (if they are checked):
Click ' OK' .
Make it easier for other people to find solutions, by marking my answer with "Accept as Solution" if it solves your issue.
Regards
Nanda Kishore Reddy
Hitech Systems, Nellore
Jun 06, 2012 | HEWLETT-PACKARD G72250US Laptop
For my compaq tablet tc4400, the right side of the touch pad has a column of horizontal lines that I believe HP calls the "scoll zone." The problem is for a right hander as myself, whenever my...
Go to control panel -> Mouse -> "Device Settings" tab (has the synaptics logo to the left of it) -> Select your touchpad -> "Settings" -> expand "Scrolling" -> "One-finger Scrolling" -> uncheck "Enable Vertical Scrolling" and also uncheck "Enable horizontal scrolling"
If you don't have "Device settings" in the mouse setting window, then you need to install the drivers from http://www.synaptics.com/support/drivers
Dec 31, 2010 | Computers & Internet
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
How do i use my touch pad to work horizontally or vertically
To enable the touchpad scroll features, you you have to install the touchpad driver. The basic touchpad features work without the driver installed but the scrolling requires it.
http://tinyurl.com/ybvag6o
Mar 06, 2010 | Dell Inspiron™ E1505 PC Notebook
How to enable the 4-way scroll button on Acer Aspire 5610 Series?
Synaptics touchpad. This is generally down by the clock (TSR program) or within All Programs. In there you can Enable side (horizontal) scroll on the touch pad as well as vertical scroll and scrolling speed.
Jan 13, 2010 | Acer Aspire 5610 Notebook
I don't know how to use the scroll areas to the Right and Bottom of the Touchpad on my Dell XPS M1730
There is a software that comes preloaded with dell called Synaptics Pointing Software .See to that it is installed.From the software enable the required scrolling mode.by moving your finger up and down slightly pressed along the right most areas of the touch pad allows vertical scrolling while moving the finger horizontally at the bottom side of the touch pad allows horizontal scrolling.Also see to that the synaptics software is enabled at startup
Sep 29, 2009 | Dell XPS M1730 Notebook
Vertical scrolling not working
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Not working for my vertical scroll zone howcan activate this problem
Assuming you're talking about the touchpad, this can be enabled and disabled in your control panel.
Open your start menu, then Control panel, if it's not in classic mode click the Classic View link in the top-left corner. Now open the mouse icon and select the Device settings tab(red logo), now click the settings select by single clicking the synaptics touch pad from the list. click the settings button below the list and select the "Virtual Scrolling" section.
You will see two check boxes, the First enables the marked off vertical scrolling feature, the second enables a horizontal scrolling feature that may not be marked on the mousepad but runs along the bottom of the pad and works the same way.
Click OK, on both windows and close the comtrol panel.
Hope this helps FixYa, if not reply back with any additional info you can,
Chris
May 12, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
