Question about Philips Audio Players & Recorders
I have a Philips 212 Electronic turntable. The bracket that holds the cartridge is broken and I need a needle. The number on the cartridge is, Empire 2001 MK 1. Can you help me?
I have A bracket for sale 25 euro
And I have the original cartridge Gp400 for 50 euro
Kind regard Jan
Posted on Oct 03, 2009
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
Numark needle broke
Generally yes. Just type the cartridge number into Google and it should find the right stylus - not needle!!!
Dec 28, 2012 | Numark ttUSB Turntable
I have Pioneer pl202az record player.. need help finding to replace the broken needle..
It is seldom worth just replacing a needle. It's not much more expensive to replace the whole cartridge. Easily available online - search by make and model number on Amazon
Feb 22, 2011 | Pioneer PL-990 Turntable
The needle is broken off can it be fixed for less then the turntable cost?
Yes it can. On the head of the arm if you look carefully where the needle (to give it's correct name -stylus) is. What it fits into is a cartridge. If you can see letters or numbers on it that will be the type. If you put that into Google it should find it. You should find if it is possible to buy the stylus with or without the cartridge. Though it's often cheaper to buy both. The cartridge will either be screwed onto the head or just clipped on someway. You will find four wires attached to the cartridge. These will have to be removed if you have to replace the cartridge. Make a note of how each wire attaches to the cartridge. As long as you can get a cartridge to fit the headshell you can use any magnetic cartridge for the job. All you would need to do with a different cartridge is adjust the weight to apply the correct pressure to the stylus.
If the cartridge doesn't have any number etc on it, put the make/model number of the turntable into Google adding cartridge/stylus.
Jan 05, 2011 | ION Audio Vinyl Recording Turntable
I can't find a needle/cartridge for my turntable, it's a Numark TT-1910
if you have the headshell left with the 4 little wires hanging out then you will need a complete cartridge.
turntableneedles dot com/Half-Inch-Standard-Mount_c_49632.html
if you have the cartridge part then it's still good and you only require a new needle. Type your cartridge number into the search window at the above website.
Apr 24, 2010 | Numark TT1910 Turntable
Broken needle on thorens TD 158 turn table.
Needle is a term used with 'record players' from the 60's. A turntable has a Phono Cartridge with a stylus. Depending on the brand / model of said cartridge the stylus may be replaceable. The cartridge certainly is. The tonearm is a delicate precision mechanism that will last lifetime if handled properly.
If you don't understand any of this I discourage you from taking any further actions without a knowledgeable mentor / technician looking over your ahoulder.
Mar 22, 2010 | Audio Players & Recorders
Need a needle for a magnavox AS305M turntable, can not seem to track one down
Unfortunately, the needle spec is tied to the catridge not the model of the turntable. Are there any numbers on the cartridge itself? Do you have a needle that is broken or is it missing completely? If you can post a picture of the needle, I should be able to match it. Post any numbers you find as well.
Thanks,
Dan
Feb 26, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
Aug 10, 2008 | Philips Audio Players & Recorders
601 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
