Question about Sony CDX-L280 CD Player
How can I remove the preset volume level on my Renault Clio. I increase it to level 25 but when I switch off the ignition it reverts to level 15 every time the engine is started.
  • wrp Sep 13, 2009
    All the radios on my previous cars did not have this preset volume, so I don't think it has anything to do with use of power.
    Problem Solver:
  • 4 Answers
Actually you should not overwrite these settings....
your stereo "eats" a lot of power which is needed for starting the engine, which cannot be redirected to the audio system. If your audio has these presets, it's for saving battery so you don't run out of power.
Posted on Sep 13, 2009
Renault clio 2001 manual. starts every time when cold. Once warm and the car is switched off it will not start for 15-30mins. Immobilizer light goes out with both keys so assume that immobilizer is ok
Not really up on the Renaults. But the usual things that could be wrong with your conditions are. The coil and or ignition module is bad. Also the starter can do this, if it doesn't turn over with the key. All when hot, can be bad and can keep the engine from starting. But work fine when cold.
Nov 02, 2014 | Renault Clio Cars & Trucks
Where are the Headlight relays on 2002 Renault clio
The headlamp circuit is rather simple. From the 15 amp RH headlamp fuse, there is a red w/yellow trace that goes to the RH high beam. Out of the 15 amp LH headlamp fuse, the wire going to the LH Hi beam is solid red. Both of these wires should have power when the headlamp relay is energized. The wires from the Hi Beam bulbs going back to the switch should both be red w/black trace. The wire going from the headlamp relay to power the 2 15 amp fuses is white. The headlamp switch applies a ground to illuminate either the Lo Beams or the Hi Beams.
Sep 11, 2012 | 2002 Renault Clio
Grand scenic indicators not self cancelling
Your turn signal switch is most probably faulty. You will need to replace it. Please, check the videos below. The first video shows a similar problem on a Renault Clio. The second one shows the operations to replace the turn signal switch. I think that the operations are quite similar in most modern cars. Good luck!
Turn Signal Switch Problem - Solved
http://www.youtube.com/watch?v=s0MQvwzXFIk
How to Easily Replace a Turn Signal Switch - Clio 2 and other Renault/Dacia
http://www.youtube.com/watch?v=JKiy-F8pd6o
Turn Signal Switch Problem Solved How to Easily Replace Turn Signal Switch Clio 2 and other Renault Dacia
Jun 12, 2012 | Renault Grand Cars & Trucks
Can you tell me roughly how much it will cost at a garage to have the fan belt on my renault clio 1.5 tightened (02). I had a new fan belt fitted approx 3 months ago but think it may need to be tightened...
Hi and welcome to FixYa!
It will cost you atleast $15 from a backyard mechanic or $25 max.
Hope this shed some light. Have a good one and thank you for using FixYa!
Feb 16, 2011 | Renault Le Car Cars & Trucks
Hi i have just had my car Renault Clio on a 06
- By dancer23 on Feb 18, 2010 -
Earlier i posted a question requesting how to switch off the service light on my Renault Clio, i have found an answer to thios, as follows.
How do you reset the service indicator light 2007 renault clio?
Turn on the ignition, but don't start the car. On the right stalk there is a toggle switch that hinges up and down, and is used for going through the different features of the display. When the display shows 'Service Due' press and hold the top part of this switch for 10 seconds until the dispaly resets and it shows 30,000km or whatever until next service.
all of the above is correct apart from pressing the toggle button. if you instead press the bottom toggle button for 10 seconds the display will start to flash. Keep button depressed and 5 seconds later the service counter will reset.
I know this works as i have just done it myself,
I hope this will help many others .
Feb 18, 2010 | 2006 Renault 181
The light switch functions correctly with the
I have exactly smae problem with my Clio, if you have the cure please email me at p@remmington.plus.com
Jan 16, 2010 | 2002 Renault Sportwagon
Renault clio window button
you dont need a diagram to change a switch!!
simply remove switch panel from door rest using a torex headed screw driver unclip switch and replace with new or second hand 2 mins work!!
Apr 14, 2009 | 2005 Renault 181
Keying in radio code on renault clio
You look at presets and read left to right >>>Good Luck
Jan 10, 2009 | 2000 Renault 181
Renault clio 1996 the heat is not working(so old)
you may be low on antifreeze, or the switch in your dashboard is not working properly. Check your radiator for proper antifreeze/coolant level first
Jan 05, 2009 | 2000 Renault 181
Sony CDX-L280 CD Player Logo
103 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
