Canon IR 2200 manual - Office Equipment & Supplies
There are functions on my ir 2200 copier which i dont understand so am asking if there are user manuals and where can i find them?
Posted on Oct 04, 2012
    Sniper:
  • 89 Answers
Check out canon.it website it has the copy and reference guides from memory.
Posted on Sep 24, 2009
    Scholar:
  • 88 Answers
    Guru:
  • 389 Answers
Canon iR2200 / iR2800 / iR3300
Некоторые ошибки зависят от того, какая опция установлена: например, ошибки E514 для Saddle Finisher-G1 и Finisher-J1 имеют разные причины.
Код ошибки Субкод Описание E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter E001 0000 The main thermistor detects 250oC or higher 0001 The main thermistor or the sub thermistor detects overheating (hardware circuit detection) 0002 The sub thermistor detects about 295oC or higher E002 0000 The temperature of the fixing film is as follows:
  • has exceeded 100oC, but does not reach 115oC within 1 sec thereafter.
  • has exceeded 140oC, but does not reach 150oC within 1 sec thereafter.
  • has exceeded 160oC, but does not reach 165oC within 1 sec thereafter
  • E003 0000 The main thermistor reading is lower than 140oC when paper is moved 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 An error in the rotation of the fixing film is detected.
    The reading of the main thermistor is 100oC or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven E010 0000 After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec
    Posted on Sep 13, 2009
    4 Suggested Answers
    • 199 Answers
    SOURCE: canon ir 2200 Error code E000064-0000
    E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
    has deviated from a specific level of voltage.)
    Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
    Action
    1. Contact
    Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
    YES: Clean the contact, and set it once again.
    2. Wiring
    Is the wiring between the contacts for the following normal: DC controller
    PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
    a. DC controller PCB (J301) <-> composite power supply PCB (J136)
    b. composite power supply PCB (J130-7) <-> primary charging roller contact
    c. composite power supply PCB (J130-1) <-> developing assembly contact
    d. composite power supply PCB (FT133) <-> transfer roller contact
    NO: Correct the connection.
    3. Composite power supply PCB, DC controller PCB
    Try replacing the composite power supply PCB. Is the problem corrected?
    YES: Yes.
    NO: Replace the DC controller PCB.
    Posted on Feb 26, 2009
    iservice
    • 318 Answers
    SOURCE: Where is the Waste Toner Bottle
    It is at the left lower panel unskrew the one skrew and remove the bottle.remove the waste toner and KLEEN THE NECK OF THE BOTTLE.e16babc.jpg
    Posted on Aug 18, 2009
    iservice
    • 318 Answers
    SOURCE: clear E000002-0000 on canon ir 2200
    Press the usermode star and release and then no 2 and 8 togheter and relealese,press the usermode star again.The machine will go in to service mode.Select copier and then on the next screen select funcktion and then clear.press the error and select ok.Switch the machine off for a minute and on again.The machine should be ok.After the clear has been done and the error is still showing then the fixing unit is faulty.
    Posted on Dec 12, 2009
    Solution to erro e000007 on ir 2420 copier
    What is remedy error code E000007-0000 for canon ... - Fixya
    www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
    Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
    Imagerunner 2200 error E000007-0000 - CopyTechNet.com
    www.copytechnet.com > ... > Copier Technical Discussion > Canon
    Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
    Jan 30, 2013
    Error Code The dreaded e000007-0001 error code!
    Sep 5, 2011
    Error Code Color ImageRUNNER 4060i has code ...
    Jun 30, 2011
    More results from www.copytechnet.com
    Nov 05, 2015 | Office Equipment & Supplies
    E000007-0000 error in diplay
    The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
    fixya.com/support/t6195187-cannon_ir2018_system_error_e007
    November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
    E007 code is occurring for the IR 2200 / 2800 / 3300
    Solution :
    In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
    you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
    Nov 02, 2010 | Office Equipment & Supplies
    Problem with printing on canon ir 2200
    go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
    Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
    Ir 2200 hard drive crash
    That's probably because you're not a tech. The hard drive is not a user replaceable part. Get a tech to replace the hdd, format and install system software using sst.
    May 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
    Code error of Cannon IR3300 E000006-0000
    getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
    Solution :
    Apr 29, 2009 | Office Equipment & Supplies
    Canon ir 2200 print from oracle
    ive had this before its under your printer setting tools you have to set that copier for tray 1 or letter turn off automatic
    Sep 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
    1,081 people viewed this question
    jasbo
    jasbo
