VD picture in b/w when connected to tv by scart via Kabel Deutsch
Loewe Arcada 72 Tv. Have just connected my dvd player (Xoro HSD 8430) via scart cable through Kabel Deutschland cable-tv box and get sound ok but vision is in black and white. Cannot locate user tv manual in flat. Any help much appreciated Nigel
  • The Vanguardian
    The Vanguardian May 11, 2010
    Try taking the DVD player out of the loop, go from the cable box to the TV and see what you get. If everything looks correct, then your DVD player needs to be set to the common channel that your TV uses for the cable box.
    President:
  • 1,566 Answers
From your remote control of the DVD player, do you see the NTSC/PAL button? While you are playing the DVD kindly press that button until you get your screen color. This will most probably solve this problem.
If this does not fix the problem, I can suggest other solutions.
Posted on Sep 13, 2009
How do I connect to tv there is nothing on the screen from the DVDs player
It depends on your connections for one thing. I did find this piece of information on the DVD player:
"One thing they do not state (in the manual) is that if you are playing it through your Scart socket to your TV. Your TV's Scart socket must be PAL60 compliant".
If they both have HDMI sockets I would get a HDMI cable and connect via that. You will also get a better picture than a scart.
If you are using a scart the connector can also become faulty either inside or a faulty pin so check that too.
Dec 14, 2014 | Alba DVD-108 DVD Player
I have a loewe arcada 8784zp tv which i brought to philippines from australia. i cannot get picture when connected to cable, but dvd connection ok so its not the tube. i also have a loewe arconda tv and...
check your cable wire some of the cable wires screw downs goes bad if thats the case there like 10 20 cent at walmart and all you neen is needle nose and a sharp nife to put them on.
Feb 22, 2011 | Televison & Video
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Trying to connect a dvd player to the tv
has the television got a/v inputs as most of the dvd players run through a/v rather than coax cable
Mar 07, 2009 | Loewe Table PLA530 30" TV
Connecting to tv with directtv
The usual way to connect a dvd is via the scart socket as dvd players seldom have an rf output (aerial type output) if you tv does not have a scart there may be phono plugs usually marked red,white,yellow the yellow is video(picture) the other two red/white are audio left and right.
Sep 23, 2008 | TruTech TT320
How to connect two vcr via scart cable over old tv
what you mean old tv ? with not scart conection?if yes,conect first vrc to second vcr via scart and second vcr via rf cable to tv if no scart socet on tv or via scart if tv have scart conection.
Aug 14, 2008 | Televison & Video
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
I am not getting a picture only sound from my dvd player. What do I have wrong?
if you have connected it to tv via a scart lead, make sure it is fully in on both ends, if it is not fully in, you will get sound but no picture, failing that, try a different scart lead
Jul 02, 2008 | Philips Televison & Video
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
