Question about Refrigerators
Not cooling, fans are running but maybe a switch is gone?
    President:
  • Refrigerators Master
  • 1,922 Answers
Either the contactor on the compressor is defective or compressor itself is low on refrigerant(freon)
Posted on Sep 13, 2009
Our new Dometic DM2852 will not stop running. Help!
Old solution from a forum but it get sense.
Citation: "It seems like there could be several possibilities:
1. Refrigerator is struggling to keep cool - maybe because of high outside temp, maybe bad seals, maybe other issues. Fan runs all the time because the back of the frig is hot.
2. Refrigerator is cooling ok, but fan runs all the time because there's poor ventilation on the back - maybe vents are blocked in some way.
3. Refrigerator is cooling ok, but fan runs all the time because it has a defective or improperly adjusted ventilation thermostat (that controls the fan).
4. Refrigerator is cooling ok, but fan runs all the time because Dometic did not include a thermostatic control on this model.
I'd suggest checking the manual or calling Dometic to ask about #4. If there is a thermostat controlling the fan, it may be covered under the Dometic warranty (which might be longer than 1 year)."
Feb 06, 2018 | Refrigerators
Radiator fan runs after ignition is off and key is removed
Does the fan motor shut off after a time or does it run your battery down?
If it runs for a time and shuts off, this is normal with a lot of cars today. It is a second stage cooling system that keeps cooling even after the motor is turned off. They all have either a temperature control or timer switch that turn them off.
If the motor runs till your battery is discharged then the temperature or timer control switch has gone bad and needs to be replaced.
Should you find that your car is overheating while in town, then the fan motor or sensor switch are usually what is at fault and will need to be evaluated and replaced accordingly.
Dec 27, 2013 | 2007 Jaguar X-Type 3.0 Sedan
Cooling fan wiring
the cooling fan itself maybe your problem, high resistance due to the motor being internally shorted but not totally gone, sounds like it my let you down shortly, I'd replace the cooling fan motor and burnt connector.
May 31, 2013 | 1999 Ford Escort
Engine cooling fan stopped running. I checked fuses all good.
Should have a relay for the fan, but typically the coolant temp switch will go bad, not the temp sensor but the switch which is usually located around radiator. Most parts stores carry them & should be able to assist you with the proper location as well.
Jan 15, 2011 | Mercury Grand Marquis Cars & Trucks
On my 1998 vw beetle the cooling fans are not running, I have changed the coolant temperature switch, the fan module switch, and the sensor on the radiator. Would the thermostat keep them from coming on?
The cooling fans work with a sensor. It has to reach a certain temperature in order for it to work. Maybe it is not the fan. Fan not coming is definitely caused by a faulty thermostat.
Dec 09, 2010 | 2000 Volkswagen Beetle
Have a 04 golf 2.0 with a CEL on; code: P2181. Engine doesn't run hot, plenty of fluids, suspect either a temp sensor or a thermostat. Is it safe to drive if it runs well otherwise?
P2181 - Performance Malfunction in Cooling System
Possible Solutions
* Check Engine Coolant Temperature Sender (G62)
* Check Coolant Thermostat
* Check Engine Cooling System
o Put the key on, fan speed on 1, and push the a/c switch. Are both fans kicking on? If not, you found the problem.
o Put the key on and fan speed on 1. Does heat come out readily from the vents?
+ No. Probably the water pump is gone.
+ Yes. Probably the thermostat is gone. good- luck!!
Aug 01, 2010 | 2004 Volkswagen Golf
Overheating car will shut off after 20 min will run again
maybe replacing the thermostatic fan switch would fix it.
Sep 23, 2009 | 1999 Buick Regal
My freelanders cooling fans keep coming on
have you checked the fan switch which should be on the radiator, maybe faulty and operating at the wrong tempreture.
Sep 05, 2009 | 2003 Land Rover Freelander
Cooling fan wont come on when car reaches operating temp
There is either a break in the cable, which when you push the plug back on you get connection, or the switch is gone. I would say there is a break/lose connection where the cable joins the plug that actually joins the switch. try this. Get a pair of pliers and crimp the joint tightly. If this doesn't work, cut the wire as close to the plug as you can, bare about 5mm of the end of the cable, slip it into the contact side of the plug and push onto the switch, then if it's still the same do the same with the other side. Bet it works! Go to a motor factors, get two new plugs to fit on the prongs, crimp the bared cable into the plugs and he-presto! A repair for $1.00
Jul 23, 2009 | 1999 Oldsmobile Cutlass
2000 Altima - when fan starts (to cool engine
Might be the fan bearings are going bad and letting the fan wobble abit on start up. Check for cracked fan blade, or loose.
Jul 12, 2009 | 2001 Nissan Altima
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
