Question about Samsung RS2630SH Side by Side Refrigerator
THE FRIDGE IS COOLING
WHEN THE FRIDGE IS PLUGGED IN , THE MOTORS IS NOT COMMING IN TO COOL THE FRIGE
The fan unit on these refrigerators tend to break often and cause overheating.Replace fan motor emmediatly.Simple disconect and replace with new fan unit.
Posted on Sep 25, 2009
  • 142 Answers
Could be ice build up around the fridge fan.
Posted on Sep 14, 2009
What would make refrigerator not run no lights or anything
There is a good chance that in the wall a wire may have come off the plug. I would try plugging the fridge in somewhere else to see what happens. If that doesn't solve it there must be a bad connection from the plug end to the frige. I would pull the back off of the frige and inspect for loose wires following the power cord into the fridge
Sep 06, 2012 | KitchenAid Refrigerators
My frige and freezer is staying cold but water is leaking from the top of fridge where cool air is pushed in from freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 27, 2011 | Microwave Ovens
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
I have a ge frige that the freezer works but frige is warm
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
heatman101
Apr 25, 2011 | Refrigerators
Lg fridge code er ff does not cool in fridge
ER FF is freezer fan motor failure code. this directs air into the fridge compartment from the freezer room. dead fan=warm fridge.
Jun 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge fan motor is making a wining noise constantly when fridge is shut, seems continually cooling
if fan motor making noise its not turning fast enuff to get frige cold enuff to shut off replace it
Dec 27, 2009 | Fisher Refrigerators
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
239 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
