Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Model KDFE55A20 plays for 1 min. cuts off for 30 sec. on and on
The pictue cuts off about 1 sec before the sound and on about 3 sec before sound.
I solved my problem with my sony projection T V join our elite plan and i'll tell you how.
Posted on Sep 15, 2009
Lg32lc46 lcd tv cuts off after a while
It sounds like a back-light inverter board fault. Check it. Replace it if needy. Normally, these boards has no repair. Replacement only can be done. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 24, 2013 | Televison & Video
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
Wont stay on. It'll load for 3 secs then turn off
The Calculator has a feature that takes it into standby after a certain delay of inactivity. Possible values of the delay are 1 min, 3 min, 5 min, 10 min, and 30 min.
In view of this, your 3 sec value seems too short. I suspect that the batteries are depleted.
In OS 2.x, press 5: Settings & status, then 3:Handheld Setup. Look for drop down box to the right of Power Standby, and select a longer delay.
Feb 04, 2011 | Texas Instruments TI-Nspire Graphic...
File corrupt, Computer unable to detect...
try going in to my computer to find the mp3 player
Jun 22, 2009 | Creative Labs Nomad MuVo2 FM MP3 Player
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Psp will Play video but the sound will cut out after 1:30 min
I guess after getting the videos, please use this tool to convert;
Step 1. Download this PSP videos 9 from http://www.pspvideo9.com/ and run it on your computer.
Step 2. Double click on the software to open it.
Step3. Click on Convert > Current Conversion > One-Click Convert andthen the pop-up for the directory comes up. You can then choose thevideo from the directory where it is saved on your computer (desktp,folder,...etec).
Step 4. Click on "Open" and then the conversion starts automatically. Allow the conversion go on to 100%.
Step5. After completion click on Library > Local Files > Open Folder,the file's original directory opens up and you can now copy to your pspvia cable or memory card (memory card reader).
You can convert and watch any video to the format your psp could play.
Regards
Jan 11, 2009 | Sony PlayStation Portable (PSP) Console
KDFE55A20 Sony
Check the connections that plug into the Block assembly. sounds like a connection issue.
Jun 15, 2008 | Televison & Video
Sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
May 13, 2008 | JVC RX-6042 Receiver
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
