Modular Home Wiring Schematics
While working on a neighbors electrical wiring in his used modular home because they lost power to their outlets and lights in the living room, dinning room, hall way to master bedroom, master bed room, master bedroom closet, and master bathroom (including the master bath room GFIC outlet). I checked the breaker box for problems and found that two different 20 amp breakers connected to the same circuit. While trouble shooting the problem I found a 'junction / 120 volt outlet 4X4 box' behind the electric stove in their kitchen with the neutral wire connection loose from the neutral wire bundle connection, all the ground wires connected in a bundle and to the outlet, the hot wire to the outlet properly connected, and (the problem) the 5 wires bundled with the hot wire to the outlet connection and all the hot wires burnt (insulation missing or chared). Using my multimeter I found which wire went to the lights and outlets that wern't working. I taped up the hot wires not used in the circuit to prevent any further shorting of the wires and connected the hot incomming wire to the outlet and the wire going to the lights and outlets that were not working before.
I could not find any connection to the other breaker that was found to be common to the breaker for the lights and outlets. I also could not find any thing that wan not working in the home. What in the world are the other wires in the outlet/junction box? Any help will be greatly appriciated.
Please contact me at bruce.shannon@gmail.com or 304 648-5101.
Thsnk you,
Bruce
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
I want to make sure that I get my home theater wired properly. I didn't realize that there were so many different things to keep track of! Maybe it would be a good idea for me to get a professional to handle this for me. http://www.futureelectrics.com.au/services/24-hour-emergency-services/
Posted on Nov 27, 2017
    Novelist:
  • 77 Answers
I disagree totally. Nobody wastes copper wire, especially idiots (because they make less money). Thoose extra wires are VITAL. The way to identify them would be to get a long extension cord, long enough to reach main breaker box. TURN OFF MAIN POWER SWITCH TO ENTIRE HOME. Make sure the "line" or "hot" wires are dead (since there are two boxes looped together, this house system may not be dead just from a switch). Once you are sure nothing is hot, use a VtVm to loop through the extension cord to each wire in main breaker box (top and bottom of each line/switch) and the bundle of wires in stove/oven box, testing continuity on each one. This will identify exactly where each wire DOES go... unfortunately, then you must determine where it SHOULD go (and sounds to me like those answers will be quite different) Be sure to get a VALID ground, since the stove is used near water. On mobile homes, this means hammering a long rebar or (specific, commercial copper grd rod) into the soil.
Posted on Dec 14, 2007
  • 95 Answers
Won't be a wiring schematic for it. If it is a modular it will be wired same as a house. Unfortunaltly it will be wired by the lowest paid electrician you have ever seen. LOL. If the wires are hot, put a multimeter on them and have someone flip the breakers one by one to identify the wires and breakers. If they are not causing any problems then they are just spare connections. Don't know why they would even be there.
Posted on Dec 12, 2007
How do I find a wiring diagram for a 1996 Fleetwood mobile home Serial number PAFLS22AB42375 -WC13 MODEL 4663D I need to connect power to the other half of my home
No such thing. The *may* be a common junction point between the two halves. It is usually located near the joint by the breaker panel, however not all homes have one. Some simply run a lead from one outlet in one half to an outlet in the other half which then distributes power. It's a messed up way of doing things but that's how they do it
Jul 31, 2016 | Cars & Trucks
The information on handset says 'the line is busy' unable to make or receive calls , when i call the phone it just gives ringing tone
The fact that it just rings when you call it indicates your line is open, which could be a wiring issue at a modular jack, or the modular cord between the jack and the phone, if it isn't just that it came unplugged.
I keep an old touch tone phone handy to act as a test phone to rule out a failed phone. With today's network terminations a customer can access a test jack outside your home/premise to test the line provided by the phone company before it heads inside to your phone wiring. If the phone works there at that modular jack, the issue is inside, if it doesn't, the issue is with the line to the phone company.
Once you narrow it down to inside wiring you can inspect any or all modular jacks to make sure the red & green wires are not broken at the screw terminals and that the modular jack wires are indeed firmly tightened to the same color wire terminal screw.
And last, another phone on the same line that is off-line or not hung up could cause the phone company equipment to isolate your line until the phones are hung up for a period of time to restore the line. So check that all phones are hung up, even cordless ones associated with the base on that particular line.
Jan 23, 2016 | Lands Phones
Jenn-Air 30" slide in modular downdraft electric range completely stopped working. Household circuit breaker functioning, range is getting power, no apparent malfunction to power connection which is hard...
Well, it's either all the burners are burnt, or power is not getting to the unit. You have to check where the power stops. Fuses/breakers on the unit? Bad switches? Loose wire?
May 13, 2014 | Kitchen Ranges
Why is the blue wire on blower relay sparking when motor comes on
Bad connection. Shut off the power and re-crimp the connector or replace it. Take a picture of the connector and go to the hardware store and ask a sales associate for the connector.
May 10, 2014 | Coleman Mobile Modular Home Electric...
How to replace element
have to disconnect electrical wires power. pull the unit as a module then you can change elements
Feb 01, 2014 | Coleman Mobile Modular Home Electric...
Assembly instructions for aspen Barolo 6 piece modular office
most modular desks have a groove around the top of the base unit that small clips lock and pull the top to the base when the screws are tightened
Jun 09, 2013 | AspenHome Aspen Barolo Modular Home Office...
Please give us wiring diagram for KXTA308. How to install
Wiring diagram? Does your cabinet hve 11 jacks on the face of it marked CO 1, 2 and 3 and Jack 01-08, plus a PAGING and EXT MUSIC port?
Pretty simple. You take a modular cord with 4 pins and feed it to a 4-pin jack wired the same way as the rest of the jacks. The polarity doesn't matter, but the voice and data positions do. Something like KSU Patch cord Modular jack Cable Modular Jack and then you plug the phone into the second modular jack. There are suppliers that make special cables to feed your inside wires, but I am guessing you are not in the U.S., so they don't apply. Try finding the equvalent in your country.
Carl
Sep 11, 2010 | Panasonic KX-TA308 Phone
I'm wiring my home for phone & internet with a single cat 5 wire. Is this possible
Hi mcdevitta,
I know that the internet will need to use a cat 5, but I don't think a phone will work on a cat 5 wire. A phone wire is a modular 4 wire cord, Now if you purchase VOIP type phones then yes you only need a cat5.
Good Luck,
Mark
Oct 09, 2009 | Computers & Internet
4pin blue modular plug under dash for brake controller to plug in
You should be able to access the Prodigy Instructions ie Wiring Diagram At google. Maybe an install video on You Tube. Make sure everything you do is properly fused. Any thing as far as color codes will need to be Prodigy specific. Prodigy may have a 1-800 Tech line. They should be able to E-mail you a PDF file.
Feb 28, 2017 | 1999 Dodge Ram
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Computers & Internet Logo
1,450 people viewed this question
Alun Cox
David Payne
David Payne
