Question about Boating
Need to know spark plug gap for a mariner outboard 8hp
  • 3 Answers
My manual says 40 thou.
Posted on Aug 14, 2010
    Guru:
  • 597 Answers
Try .45 - .50
Posted on Oct 18, 2009
Please - spark gap for 4 HP twin two stroke johnson outboard
.025"
you should be using multi discharge point plugs in out board motors -not regular car engine plugs and the gap is preset on them
the reason being , with multi point discharge they are less likely to foul from oil and carbon build up
available from any good auto parts shop or marine shop
Feb 13, 2017 | Johnson Boating
Spark plug gap for 1990 evinrude express v6
The gap is 0.030
Pretty-much the gap for most of the motors in evinrude line-up during that era.
Sep 06, 2014 | Champion Spark Plugs Marine Spark Plugs...
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Mariner outboard engine 4cylinder what type of spark plugs do I need
marine spark plugs are of the anti foul type so it will have 2 or 3 or no side electrodes ( earth point) and this is to prevent fouling of the plug across the gap. They are available from most car spares shops but you can get them from the outboard shop . The reach ( length of thread is very important) and you can get a range from cold plugs to hot plugs depending on the age of you motor and how much fuel or oil you use . Talk to the marine dealer for exacting advice.
Jul 31, 2013 | Boating
Yamaha 2.5 hp outboard motor spark plug gap
I Would Recommend a 0.8 Gap
Mar 10, 2013 | Boating
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Yamaha outboard 150 4 stroke bad vibration at 700 to 1200 rpm run great in nuetral and over 1200 rpm what could it be
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Nov 03, 2009 | Boating
Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Sep 29, 2009 | Boating
Boating Logo
272 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
